Anyone have one of these leak?
http://store.summitracing.com/partde...t=EAR%2D809108
Im wondering if these swivel fittings can hold much PSI and if anyone had these leak. I have one on my car and I think its spraying oil after my turbo drain line everywhere at high boost.
If it's on the drain side, the only reason it would be leaking is from the hose not being pushed in all the way. You should disconnect it and push the hose in all the way into the sleeve and then mark it with a sharpie. Then when you install the connector, you can tell if the hose backed out.
Had one fall apart on my fuel line and I learned about seating them the hard way.
