lean condition
Old May 16, 2008 | 03:34 PM
97sscamaross's Avatar
lean condition
I had an ses light come on the other day and it's been coming on and off intermittently over the past few days. When it came on today I went to advance auto parts and had it scanned and it said that there is a lean condition on bank 1.
Old May 16, 2008 | 06:45 PM
maybe2fast's Avatar
do you have a header gasket leak? that can cause a false lean code. Also a vacuum leak. check the obvious before you replace parts. also get the code number for us, it my help
Old May 27, 2008 | 11:40 AM
I found the problem, the rubber elbow on the pcv valve was torn and had a huge hole. I replaced it and the car seems to be running a lot better, especially at idle. no more code. Damn vacuum leaks
Henson071
Sep 18, 2015 04:01 PM
4586
Aug 18, 2015 07:08 AM
Henson071
Aug 4, 2015 09:32 AM
Boss002
Jul 24, 2015 10:47 AM
Noct
Jul 14, 2015 01:18 AM
