Lean @ idle and engine breaking
Old Feb 4, 2008 | 08:54 PM
jchevy's Avatar
Just got my turbo setup going on my LT1. I also installed a wide band. I am lean at idle, 16-17:1 and if I down shift and engine break my wideband says full lean. 22.4:1
If I touch the gas peddle at all it comes right down to 13:1. Any ideas? Could this be a vacume leak?
Im not sure if it was like this before the turbo or not?
Old Feb 4, 2008 | 09:37 PM
mdenz3's Avatar
On engine braking the ECM shuts the fuel injectors off. What are you pre-cat O2's reading at idle?
Old Feb 4, 2008 | 10:04 PM
jchevy's Avatar
I am currently running an open loop tune, I dont have any o2s in the car right now.
IAC counts are staying at 20, so I dont think I have a vacume leak.
Old Feb 5, 2008 | 05:04 AM
Guest47904's Avatar
Guest
Is your FPR boost referenced? Nyway, this belongs in the forced induction forum.
Old Feb 5, 2008 | 08:28 AM
jchevy's Avatar
I figured this would go in LT1 tech b/c im not under boost at idle. I have a boost sensitve FPR, but its not on the car yet. Should It matter if I am at idle not under boost?
My AFR is fine everyplace else.
grabbem88
Feb 13, 2015 03:09 PM
edman
Jan 25, 2015 02:41 PM
David Dorris
Jan 17, 2015 08:10 PM
Lions3
Apr 11, 2003 10:55 AM
