leaky water pump
Old Dec 19, 2004 | 04:00 PM
95dragon's Avatar
Question leaky water pump
I got a leak from the back of my water pump. It is a 95 lt and it only leaks while the engine is running. Does it need to be replaced or can I repair it withot a new one. Any recomended pumps if I need to replace?
Old Dec 19, 2004 | 04:04 PM
Sleeper_Z's Avatar
Re: leaky water pump
It sounds to me like the weep hole is leaking on the water pump. Id replace it. Some people say its a pain to change but its not that bad.
J.
Old Dec 19, 2004 | 04:11 PM
fragenstein's Avatar
I'm not TOO experienced... but if the water pump is leaking from behind, and the opti is behind it... you MAYYYYY wanna change that soon.
Old Dec 19, 2004 | 04:14 PM
Sleeper_Z's Avatar
Yeah I agree with fragenstein, id replace it asap. And when you do you will want to cover the opti with a rag or 2 to prevent coolent from running out all over it.
J.
Old Dec 19, 2004 | 05:36 PM
95dragon's Avatar
wat is the OPTI?
Old Dec 19, 2004 | 05:38 PM
Sleeper_Z's Avatar
It is the box under the waterpump that all the plug wires run into. Its the distributor on an LT1.
J.
Old Dec 19, 2004 | 05:39 PM
Hawk's Avatar
I had the same problem, I replaced my water pump with an electric unit. However, a few weeks after the job the opti went and I have a new one on the way, I suggest you replace the pump immediatly.
Brian
Old Dec 19, 2004 | 05:46 PM
95dragon's Avatar
how much do those cost? what brand would you recomend? How tough is the removal and install?
Old Dec 19, 2004 | 05:50 PM
Sleeper_Z's Avatar
A stock replacement would do the trick just fine. They are around $50 at Autzone. They arent that difficult to change. It took me about and hour or 2 to change mine. Its best to do it from under the car.
J.
Old Dec 19, 2004 | 05:57 PM
95dragon's Avatar
How much better is an electric pump? Do they really add that much more power? Would it be worth the upgrade? I may have to sell my car and I don't want to spend to much $$ if it isn't really worth it. Know anybody looking for a Z?
Old Dec 19, 2004 | 06:03 PM
Sleeper_Z's Avatar
If you are gonna sell it i wouldnt spend the extra $120 on an electric pump. Id just go with a stock replacement. What are you gonna be asking for your car?
J.
Old Dec 19, 2004 | 06:50 PM
95dragon's Avatar
5500. may just need to sll quick.
Old Dec 19, 2004 | 06:56 PM
IRONFIST's Avatar
Yah, sounds like your water pump is gone. But if you're selling anyways, I wouldn't really worry about the opti. Sure, you might have harmed it, but if it's still working good.. just throw on a new stock pump and get it done with.
Old Dec 19, 2004 | 07:37 PM
Andrew R's Avatar
Yeah that kinda happend to me...looked at the car, ran perfect. When I picked it up, it went downhill from there. Water pump started leakin on the opti, and it runs like crap now . So do replace it asap..
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
