Leaky water pump
Old Sep 19, 2003 | 05:34 PM
slmdgmc's Avatar
Leaky water pump
I noticed the other day while working on my truck that the two of the water pump bolts were loose (the two holding the drivers side gasket to the block). I tightened them up and now its leaking badly. I am fairly sure its leaking from the gasket there as that's where I can see it dripping from. Luckily I havent driven it anywhere and its not hitting my brand new optispark How hard of a job is it to change out the two gaskets of the waterpump? Anything I should look at while its off? Should I use some blue RTV on the gaskets also? Thanks for the help....
Old Sep 19, 2003 | 05:45 PM
predator's Avatar
not hard at all take the bolts off remove the pump clean the surfaces replace gaskets reinstall pump
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
