leaky valve covers, which gaskets?
Old Aug 29, 2008 | 08:20 PM
97SS0594's Avatar
right now i have cork gaskets that i made, they have worked in the past but now they are leaking like a siv! i have polished valve covers on the car and the stock replacement gaskets dont fit. which gaskets should i be using?
Old Aug 30, 2008 | 05:49 AM
Fastbird93's Avatar
Try a bead of RTV. Why won't the factory rubber gaskets fit?
Old Aug 30, 2008 | 07:17 PM
97SS0594's Avatar
there too small for mome reason.
Old Aug 31, 2008 | 12:24 AM
BoogieZ28's Avatar
I don't see why you cant find gaskets that fit, replacements SHOULD work, but I don't know what kinda valve covers you got. Anyways, as the other members say, If you can't find them just use Silicon, just make sure you do a good job and it will be a nice secure seal.
good luck
Old Aug 31, 2008 | 01:38 AM
SS RRR's Avatar
They're somewhat small on stock valve covers as well. Just stretch them out a bit before putting them on. Use a bit of silicone on all four corners to keep the gasket in place if you have to. Screw that cork crap.
Old Aug 31, 2008 | 02:10 AM
Colin's Avatar
Cork gaskets are absolutely useless because they harden and have little compression. The neoprene (blue) gaskets are pretty flexible, dude. Leave them out in the sun for a few minutes and try again. Another possible solution would be to use some blue ones but cut them in the middle and patch them together with silicone. You want that compression, my friend.
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
