leaky oil filter
Old Apr 28, 2003 | 09:13 PM
worak's Avatar
Angry leaky oil filter
today after i changed my oil my filter started to leak. i put another filter on but it still keeps pouring out. both filters have gaskets in them, whats the deal.
Old Apr 28, 2003 | 09:16 PM
chasmanz28's Avatar
Re: leaky oil filter
did the old gasket come off the old filter?
Old Apr 28, 2003 | 10:36 PM
worak's Avatar
there was a gasket on the old filter, is there another gasket im missing . ive always changed my own oil, this has never happened before. oil streams out whenever the car is running
Old Apr 28, 2003 | 10:41 PM
Javier97Z28's Avatar
Moderator
Check and make sure there is no gasket material on the mating surface of the filter where it mounts to the engine.. some may have been left over (rare, but possible I guess) from an old filter... make sure it is nice and clean and has no gouges of any kind..
Also, are you lubricating the seal before you put it on?
ShelbyZ28's Avatar
If its streaming out you probably put the filter on wrong. Check and see if you cross treaded the filter.
Old Apr 28, 2003 | 10:59 PM
worak's Avatar
yeah im putting a little oil on the gasket before i install, if ive crossed up the threads is there anyway to replace or fix the problem. this is so frustrating, thanks for the help guys.
Old Apr 28, 2003 | 11:45 PM
Lt1t56's Avatar
Do you have an oil cooler ? This happened to me once after changing oil, had leak that looked like it was from the filter, it wasnt, was the oil cooler leaking, when I removed the oil filter it must of loosened the oil cooler.
Old Apr 28, 2003 | 11:50 PM
chasmanz28's Avatar
i know this sucks dude, something so simple and yet hard to find out whats going on, im sure you will though
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
