Leaky injector confusion. Proper start up procedure verification needed.
Old Jul 31, 2007 | 08:27 PM
MR.CLIFFORD's Avatar
I'm really confused by my injectors. My 95 LT1 sat for a couple years before making it into my project vehicle. I found I had 4 injectors that were so gummed up they wouldn't open. I verified the injectors by a home made alligator clip setup.
After getting all my injectors to open and fire fuel I installed them and fired the motor. After a week now I decided to pull the fuel rail to verify all the injectors were truly firing and not leaking. What I found has really confused me.
When I prime the fuel rail with the pump I get tons of fuel out of the #1 and #4 injectors. Then they both drip but I don't get much spray from the other 6 injectors. Just want to verify this is not correct and my #1 and #4 injectors are stuck open. All the garbled mess of injector threads really has me confused!
What is the proper procedure for fuel injectors on start up? Both when Key On Engine Off and Key On Engine On.
Thanks,
Andy
Old Jul 31, 2007 | 08:47 PM
joeSS97's Avatar
Pretty easy...KOEO..(key on engine off)...no fuel should come out..KOER...they should spray individually.You should get a new set.
Old Jul 31, 2007 | 09:26 PM
Thanks. That's the way I'm headed. I found the FMS 24# injectors local for 300. I think I'm going to get them and call it done!
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Collector Car
Jan 5, 2015 10:58 AM
Rod Bender
Jan 3, 2015 03:15 PM
