leaking water pump
Old May 27, 2004 | 10:46 PM
turbostud2's Avatar
Thumbs up leaking water pump
Maybe someone has done this before, not for sure though. I was thinking the other day how to fix the dreaded waterpump leak. I found if you get a 3/16 tap in grease fitting and drill out the inside of it so you can see though it and tap it into the pump weep hole and get about 1 1/2 feet of heater hose and connect it to the grease fitting. It will go past the opti and wont get it wet next time it goes out. As for if the gasket goes out I don't think there is much you can do for that..... Anyone done this before??
Old May 27, 2004 | 10:51 PM
It's been talked about many times. A couple of people have done similar things over the years.
Old May 27, 2004 | 10:54 PM
turbostud2's Avatar
Yeah I figured that but I was bored today, maybe it will help someone out that hasn't heard.....
Old May 27, 2004 | 11:39 PM
med_reject's Avatar
Re: leaking water pump
Is there a really good explanation (photos, drawings, anything) for that somewhere? My waterpump destroyed my opti and im broke, i dont want this to happen again.
thx
Magenta_Hearts
Mar 29, 2017 08:54 PM
Blood type Z28
Apr 8, 2015 11:34 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
