Leaking SLP shorties
Old Jul 30, 2003 | 08:03 PM
DEMONSPEEDN's Avatar
I have a set of dual-cat SLP shorties that are leaking at the Y-pipe. I've tried the double gasket trick and that didn't work. There is a Y-pipe made by Stainless Works I'm considering, which has no cats. Will this cause any problems if used with O2 sims? Is there a better alternative, maybe a different gasket?
Any help would be greatly appreciated.
Thanks, Joe
Old Jul 31, 2003 | 12:22 AM
1982z28with18s's Avatar
What year car and is it the dual cat setup? Also, did you you buy new gaskets for the y-pipe to header connection?
Old Jul 31, 2003 | 04:26 AM
It's a '96. I've used new SLP supplied gaskets each time I tried to fix it. I even tried double gasketing with copper sealer and that didn't work either.
Old Jul 31, 2003 | 04:57 AM
I got my y-pipe to header gaskets from a dealer since I bought my headers used. Single gasket on each works fine.
G-BODYT56
Parts Wanted
May 31, 2015 12:09 PM
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
slocody
Feb 10, 2003 01:04 PM
97bowtie
Aug 25, 2002 11:00 PM
turbo_Z
Aug 19, 2002 10:50 PM
