Leaking injectors??
Old Apr 19, 2004 | 03:34 AM
96ta(nick)'s Avatar
Leaking injectors??
What part on the injectors actually cause them to leak? I think mine are leaking because i have gas pooling in my intake and after sitting overnight it stumbles BAD for a minute or so, when we put them on the O-rings were a little loose fitting(used 30lb svo) where can i get new O-rings?
Old Apr 19, 2004 | 10:35 AM
IDOXLR8's Avatar
Re: Leaking injectors??
Injectors usually leak at the o-ring. You may want to try your local autoparts store for some O-rings.
Old Apr 19, 2004 | 11:31 AM
HBHRacing's Avatar
any parts store wil carry an oring kit. they are about 5 bucks.
but
you say it pools on the intake with the car off? I don;t see how that would happen with a bad o ring. usualy you will have a vacuum leak with bad o rings. I would take a look at where the gas is coming from. prime the key a few times and watch for it. a fuel pressure test will also tell you that it;s leaking down
CaptainObviousI
29
Apr 29, 2021 10:35 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
NewsBot
May 15, 2015 09:30 AM
Alex Barnes
Jan 24, 2015 10:21 PM
