Leaking coolant
Old Oct 10, 2010 | 06:37 PM
  #16
bw_hunter's Avatar
Oh boy, you've made a mess.
1) Remove the water pump and clean the mounting surfaces on both the pump and the block. Use a scraper and the chemical gasket remover if necessary to get to clean bare metal.
2) Clean the mounting bolts of any and all crud. Apply teflon tape to all the threads on all the bolts.
3) Apply a little Permatex non-hardening gasket maker to both surfaces of the gaskets and stick them onto the water pump.
4) Bolt the water pump to the black..make sure the bolts are good and tight.
5) Reassemble everything else.....
Old Oct 10, 2010 | 08:40 PM
  #17
maliveline's Avatar
whats the difference between Permatex non-hardening gasket maker and permatex rtv silicon gasket maker?
Old Oct 10, 2010 | 08:49 PM
  #18
94CamaroZ28/SSClone's Avatar
WHOA! Are you not being grateful for the help?
Originally Posted by maliveline
what a colossal goat ****
Old Oct 11, 2010 | 08:58 AM
  #19
bw_hunter's Avatar
It's compatible with paper gaskets and is a proven performer in this application. RTV has it's places and might work here but Permatex s a great choice....
Old Oct 11, 2010 | 09:44 AM
  #20
RamAir95TA's Avatar
I have always used spray-a-gasket to coat the water pump gaskets. It keeps the area neat without gasket maker protruding everywhere and into the water jackets. Never once had a leak.
Old Oct 11, 2010 | 09:53 AM
  #21
bw_hunter's Avatar
LOL..I didn't even take it personally until I saw your reply. I've been called worse......
I actually thought he was talking about the situation.
Old Oct 11, 2010 | 11:47 AM
  #22
maliveline's Avatar
i was talking about the situation and i edited that post to ask a real question anyway. I think i like the idea of using a spray-a-gasket but not really sure im on my way to the auto parts store i guess i will make up my mind when i get there.
Old Oct 11, 2010 | 12:12 PM
  #23
bw_hunter's Avatar
They will both work fine. Do remember that either of these are to be used with the gasket and not by themselves in this installation.
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
Blood type Z28
Apr 8, 2015 11:34 PM
guitargod33
3rd Gen / L98 Engine Tech
Jul 14, 2002 07:00 PM
vinnyxgunz
Mar 17, 2002 08:59 PM
