LE3 head LE2 Cam LT1 what should I expect?
Old Mar 27, 2006 | 10:40 AM
Tricked-Out-Toy's Avatar
Well im getting my engine back together and am just waiting on a few more parts so id like to know what everyone thinks ill be running? heres the run down of parts
58mm tb
ported intake
30lb injectors
LE3 heads
1.6 pro mags
Le2 cam (brets 2.2)
stock bottom end 350ci (new bearing and moly rings)
stock WP
Long tube (hedman 1 5/8 primary)
MadZ28 tune
Running a t56 through an aluminum LS1 driveshaft into a 3.42 10bolt with a auburn pro dif. I also have 17" wheel with 275 40 tires
Old Mar 27, 2006 | 11:15 AM
Loadre's Avatar
Re: LE3 head LE2 Cam LT1 what should I expect?
Mid to high 11s with a good driver and DRs/slicks. Mid to High 12s on street tires.
Old Mar 27, 2006 | 11:50 AM
thats pretty much what I was thinking. Im figuring ill be right around 400 at the wheels. think thats resonable?
Old Mar 27, 2006 | 12:20 PM
Z-RATED94's Avatar
400 at the wheels sounds reasonable to me as long as you have all your ducks in a row. But unless you can launch that sweet looking ride of yours I wouldn't count on 11's. Start saving for a 12 bolt with some shorter gears. For the rest of you guys check out his web page, very nice car!
Old Mar 27, 2006 | 12:26 PM
thanks for the sweet comments, and before anyone says anything about the "ricy" interior, Im in the middle of toning it back a little Also I dont really run at the track that much, My main goal was to make the car into a sick road course car! Im dieing to hit up watkins glenn this year! with the new brakes and engine I should have a very well balanced car
Old Mar 27, 2006 | 12:58 PM
Z-RATED94's Avatar
Makes a lot more sense now. Road racing is the ****. Raced karts for years. Just make sure you keep an eye on all your temps. Don't cook anything, including your brakes. Oh and watch out for the rookies that think every lap is the last lap.
Old Mar 27, 2006 | 02:19 PM
Ya nothing like a little patience! I wish I got to race karts when I was younger! instead I was out on dirtbikes tearing up hairscrambles and enduros! there wasnt much pavement out were I grew up.
Temps are something that I will never ever be caught again not watching. I learned that leason the hard way a few years ago.
Old Mar 27, 2006 | 04:09 PM
MeanGreen97Z's Avatar
Sounds like a hard runner.... any reason you didnt go with the larger primaries on the long tubes? I'm gonna guesstimate your HP at just about 400 and torque at 370.
Old Mar 27, 2006 | 04:49 PM
well the only headers I could get that gave me the ground clearance I needed were the headmans and they only come in 1 5/8. The hookers1 3/4 were WAY to low and I would bottom out all over.
Old Mar 27, 2006 | 04:55 PM
IllusionalTA's Avatar
i'd say you can expect to break your rear end.. Sounds like a nice setup... good luck w/ it...
Old Mar 27, 2006 | 04:57 PM
Kooks too pricey? I hear they offer some really good ground clearance.
Old Mar 27, 2006 | 05:38 PM
ABA383's Avatar
Hey...guess you made it home with that rear stuffed into your car! Got Kooks installed on my 4th gen and all I can say is WOW! Worth every penny, if they make a set for your application..They are slip fit and tuck up real nice...
Take care...
--Alan
Old Mar 27, 2006 | 11:44 PM
blackz97's Avatar
Seems pretty close to my setup.
Steve
Old Mar 28, 2006 | 04:55 AM
Hey Alan, yup made it home fine, ripped the rear apart and everything looked great, the backlash looked perfect. I figured out where yuou were having issues tho. the pinion bearings were SHOT! so I stripped it and gave her all new bearing and seals and its look like a milion bucks! as far as Kooks are concerned you guys must not read my sig lol, Ive got a third gen, and I know I havent looked in a while but I wasnt aware kooks made anything for thirds. so If anyone knows of 1 3/4 primaries with better clearance than hedman please let me know!
Old Mar 28, 2006 | 06:02 AM
Ya I knew it was a thirdgen but the clearance problems should be taken care of with the kooks. They are stepped so they give more ground clearance than the hookers, jet hots, and pace setters.
