LE3 head LE2 Cam LT1 what should I expect?
Well im getting my engine back together and am just waiting on a few more parts so id like to know what everyone thinks ill be running? heres the run down of parts
58mm tb
ported intake
30lb injectors
LE3 heads
1.6 pro mags
Le2 cam (brets 2.2)
stock bottom end 350ci (new bearing and moly rings)
stock WP
Long tube (hedman 1 5/8 primary)
MadZ28 tune
Running a t56 through an aluminum LS1 driveshaft into a 3.42 10bolt with a auburn pro dif. I also have 17" wheel with 275 40 tires
58mm tb
ported intake
30lb injectors
LE3 heads
1.6 pro mags
Le2 cam (brets 2.2)
stock WP
MadZ28 tune
Re: LE3 head LE2 Cam LT1 what should I expect?
Originally Posted by Tricked-Out-Toy
thats pretty much what I was thinking. Im figuring ill be right around 400 at the wheels. think thats resonable?
thanks for the sweet comments, and before anyone says anything about the "ricy" interior, Im in the middle of toning it back a little
Also I dont really run at the track that much, My main goal was to make the car into a sick road course car! Im dieing to hit up watkins glenn this year! with the new brakes and engine I should have a very well balanced car
Ya nothing like a little patience! I wish I got to race karts when I was younger! instead I was out on dirtbikes tearing up hairscrambles and enduros!
there wasnt much pavement out were I grew up.
Temps are something that I will never ever be caught again not watching. I learned that leason the hard way a few years ago.
there wasnt much pavement out were I grew up.Temps are something that I will never ever be caught again not watching. I learned that leason the hard way a few years ago.
Sounds like a hard runner.... any reason you didnt go with the larger primaries on the long tubes? I'm gonna guesstimate your HP at just about 400 and torque at 370.
well the only headers I could get that gave me the ground clearance I needed were the headmans and they only come in 1 5/8. The hookers1 3/4 were WAY to low and I would bottom out all over.
Hey...guess you made it home with that rear stuffed into your car! Got Kooks installed on my 4th gen and all I can say is WOW! Worth every penny, if they make a set for your application..They are slip fit and tuck up real nice...
Take care...
--Alan
Take care...
--Alan
Hey Alan, yup made it home fine, ripped the rear apart and everything looked great, the backlash looked perfect. I figured out where yuou were having issues tho. the pinion bearings were SHOT! so I stripped it and gave her all new bearing and seals and its look like a milion bucks! as far as Kooks are concerned you guys must not read my sig lol, Ive got a third gen, and I know I havent looked in a while but I wasnt aware kooks made anything for thirds. so If anyone knows of 1 3/4 primaries with better clearance than hedman please let me know!
Ya I knew it was a thirdgen but the clearance problems should be taken care of with the kooks. They are stepped so they give more ground clearance than the hookers, jet hots, and pace setters.
Sounds like a nice setup... good luck w/ it...
