LE3 383 sound clip
Old Aug 11, 2005 | 03:31 PM
Zigroid's Avatar
LE3 383 sound clip
its what the title implies... an LE3 383 sound clip.
Some people wanted a video of my car and this is the best I can do
Its recorded off of my laptop heh. I dont have any video capturing devices or I would. The sound quality isnt bad until I rev it up a bit. at idle (which is about 950 rpm) it sounds just as it does in real life. in retrospect I should have just kept the mic inside the car and it would have picked up the sound fine.
car info is in sig.
here it is on some media upload site:
http://www.putfile.com/media.php?n=LE3383
or if you want to just download the file itself:
http://x502.putfile.com/videos/22215225574.wav
I dont know why its a bunch of random numbers.
once again sorry for no video but if you want to get the full effect look at THIS picture while listening to the .wav!
Old Aug 11, 2005 | 03:33 PM
hallbilly's Avatar
Re: LE3 383 sound clip
now i have to go clean myslef up
Old Aug 11, 2005 | 03:59 PM
Formula_driva's Avatar
holy hell
Old Aug 11, 2005 | 04:07 PM
JustNO's Avatar
Thats awesome!! What is your cam specs??
Old Aug 11, 2005 | 05:32 PM
93 4mula's Avatar
WOW!!!(made my noodle hard) I hope mine sounds like that when Im done building my 383. Im going with a crane cam. 240/244 .595/.595 with Pacesetter LT's, X Pipe with True dual exhaust(bullets). Man I can't wait to hear mine now... Whats the specs to that cam? How does she run?
Old Aug 11, 2005 | 05:41 PM
SStrokerAce's Avatar
Sounds Mean Pete!
To Quote him from his site...
"cam: Can't say much about this. It's custom. It's healthy."
http://www.cardomain.com/ride/520908/5
Bret
Old Aug 11, 2005 | 06:09 PM
JustNO's Avatar
All 383cid + LE3 setup sound like that?? Idle is veryyy lumpy.. I know LE3 cam is similar to gm847 cam ,but something is different in this car..
Old Aug 11, 2005 | 08:37 PM
ZMAN Z28's Avatar
Sick!
Old Aug 11, 2005 | 08:42 PM
xxsaint69x's Avatar
am i the only one that thinks it sounds like a tractor?
I am sure it is much better in real life? Sounds like it is not idleing good at all?
Old Aug 11, 2005 | 09:09 PM
MEAN LT1's Avatar
The sound clip isnt doing the car any justice or maybee it was my speaker?. But it doed sound healthy and it your idel raised.
Old Aug 11, 2005 | 09:15 PM
Victory Racing's Avatar
Sounds like its got a nice lopey idle.
Old Aug 11, 2005 | 09:29 PM
I'm betting the idle speed is really low to lope like that.
Bret
Old Aug 11, 2005 | 09:45 PM
Ram Air 9C1's Avatar
My LE3 cam in a 383 doesn't lope nearly as much. The idle is also set at 950 rpms. It lopes a little bit more than a hotcam in a 350 in a previous engine. I guess the cam specs for b-body were a little different.
How much vaccuum is it pulling at idle. Mine is at 12 Hg-in according to the gauge and 13 if you calculate it using map readings.
Old Aug 11, 2005 | 10:13 PM
Zigroid's Avatar
I don't think the car sounds as good as it should for two reasons:
1) its not dyno tuned
2) its through a loudmouth with headers. I really need a new exhaust setup.
the car runs good, I'll find out what it does in the 1/4 tomorrow.
the idle is at 900-950 rpm. it has trouble idling when first started, as heard by me hitting the throttle quick to get the rpms back up after it started. I don't know how much vacuum it produces but it does have trouble with the brakes a little. the converter has a high enough stall speed that I'll just hold the brake with my left foot and hit the throttle slightly if I ever need a brake boost.
my cam has a tight LSA compared to others, so that will contribute to some of the lope.
I cannot divulge the specs of the cam although I think it drives "smaller" than what they suggest. I can honestly say that I wish it was slightly bigger!
I have daily driven this car for 2 weeks now, 700+ miles. my only complaint is the gas mileage but that was expected, especially with my torque converter, and should get better with a dyno tune. hats off to lloyd and bret. they did a great job once again.
I'll try and get an in car sound clip or maybe borrow a buddies digital camera.
edit: oh, and if any of you are going to that east coast f-body thing at island drags on sunday you can hear it in person
Old Aug 11, 2005 | 10:34 PM
hallbilly's Avatar
i thought it sounded ungodly... just barely "hittin a lick" I hope my LE2 will sound something like that
