Le3.2 ???
Old Feb 4, 2008 | 02:09 AM
johnnyb's Avatar
Le3.2 ???
I've been searching to find out what the difference is between the le3 cam and the le3.2 but haven't been able to find anything. iirc, the le3.2 is a n2o cam, but i could be way off. anyone know the difference?
Old Feb 4, 2008 | 06:46 AM
elisowski's Avatar
You can get contact info for LLoyd Elliot at the following site.
http://www.eportworks.com/
It's his custom cam so you probably won't get anyone to give out the specs in public.
Old Feb 4, 2008 | 07:48 AM
Javier97Z28's Avatar
Moderator
The "LE3.2" which is what I have.. is most definitely not a nitrous specific grind.
Old Feb 4, 2008 | 08:23 AM
johnnyb's Avatar
im not looking for the actual specs, im just curious as to how it compares to the le3.
Old Feb 4, 2008 | 08:28 AM
89385formula's Avatar
Its just a revision to the cam, so without the specs being given out there wouldn't be a way to compare the 2.
Old Feb 4, 2008 | 10:29 AM
Ram Air 383's Avatar
It's probably just a newer revision of the LE3 cam. The real question is how well is it going to work with your heads and bottom end compared to an earlier revision LE3. Just ask Lloyd/Bret.
Old Feb 4, 2008 | 12:38 PM
johnnyb's Avatar
I actually just bought a set of le3 heads. I guess i should update my sig
Old Feb 8, 2008 | 01:24 AM
mad95z's Avatar
It would probably be slightly more agressive, than the le3 cam
96LT1TX
Nov 11, 2011 03:38 PM
johnnyb
Aug 31, 2009 02:21 PM
za355tx
Feb 5, 2008 12:51 AM
za355tx
Dec 16, 2007 11:11 AM
