It runs!!! (LE3.2 355)
Old Apr 29, 2009 | 01:17 PM
johnnyb's Avatar
Finally! The last time my trans am saw the road it was may 6 2007 on the back of a tow truck due to a spun bearing after a hotcam install. I figured it gave me room to go bigger and better so that's exactly what I did: fully forged 355 with le3 heads and le3.2 cam. I set a goal of getting the motor done last April, but due to my College budget it just didn't work out. A year later though, I finally turned the key over and she runs! I haven't got it on the road yet cause there are a few quirks I have to work out... When I started it I couldn't get it to idle but I also had a vac line disconnected so I hope that's what it is. I'm also going to go 1 heat range cooler (tr6) with .35 gap instead of stock gap. Should idle easier hopefully. Anything else I should look into as far as idle? And what kind of breaking in is suggested? Video of start up will be up soon! Ps- 3" TD with bullets and a 600 lift cam is NASTY!
8/30 UPDATE!!! Here is an idle video of the car running good: http://vids.myspace.com/index.cfm?fu...deoid=62619402
Old Apr 29, 2009 | 01:23 PM
teke184's Avatar
"Ps- 3" TD with bullets and a 600 lift cam is NASTY!"
agreed...wait till you hear it at 6000+ rpm
good work on the rebuild.
Old Apr 29, 2009 | 04:37 PM
bombebomb's Avatar
Do you have a mail order tune in it at least? If not that is why it refuses to idle.
Break in is personal opinion, I would drive it one notch before you stole it hehe.
Drive it 20 miles, make sure nothing is going to fall apart, change oil, run it.
I am changing my oil again at the 200 mile mark, then the 1000, then I am just going to change it normal after that.
Old Apr 29, 2009 | 05:28 PM
user 647483's Avatar
Yeah, you'll need at least a mailorder tune to get that thing to idle
along with a little extra throttle (adjust throttle stop). Once she's tuned and
running properly, post a vid
Old Apr 29, 2009 | 08:32 PM
stephenpen's Avatar
I'm running a cc306 cam in a 383 and my car idled right away. It was a high idle but it was an idle. Thats with stock injectors and stock tune. After the tune and injectors it has a perfect idle. I'm not sure if thats going to help you or not
Old Apr 29, 2009 | 09:17 PM
johnnyb's Avatar
ya i have a mailorder tune from ion. The idle could be so many things since i changed just about everything. Im gonna bump out the idle screw like suggested and check the iac sensor. It smells like its running super rich but i didnt run it very long at all. I also think i may have the preload set a little too tight on the lifters so im going to reset that tomorrow. Hopefully doing these things will enable it to idle at least a little bit.
The spark plug gap is also a little on the loose end of the spectrum as i just kept it at what they came gapped at... .055 I know that was dumb on my part but thats about stock so i figured why not. thats actually the very first thing im going to be doing in the morning (changing to .035 . thank god for longtubes haha!
Old Apr 30, 2009 | 11:47 PM
johnnyb's Avatar
turns out the culprit was the roller rockers were wayyy to tight causing the valves to hang open... pretty big difference now lol. (no worries... ran less than 2 minutes total probably) Still havent put it on the road but this weekend it definitely will be!
Old Apr 30, 2009 | 11:51 PM
Better to find out at low RPM than high ... *BANG**BANG**BANG**BANG*
Old Apr 30, 2009 | 11:55 PM
johnnyb's Avatar
ya tell me about it... glad i didnt put it up past 1500rpms!
Old May 1, 2009 | 10:23 AM
PWR SHFT's Avatar
Looks like it's time to change your signature. Unless the car is sitting in your bedroom.
Nice job and beautiful car!
Old May 2, 2009 | 12:38 AM
Hey, some people really love their cars
Old May 2, 2009 | 09:43 AM
johnnyb's Avatar
haha ya....changing sig now
Old May 5, 2009 | 08:26 PM
LT4POWR's Avatar
Sounds like a pretty sweet setup! Be sure and post some dyno numbers.
Old May 5, 2009 | 08:31 PM
PoorMan's Avatar
Sweet setup. Congrats. You got to feel great.
Old May 6, 2009 | 12:38 PM
krillformula's Avatar
Nice build! I want to hear that beast!
