LE2 Stock bottom end lt1 426rwhp 393rwtq through ford 9"
i cant really say but i will say that my cam is smaller than both of those cams you just listed. also my cam is a nitrous cam that im not runnin nitrous on so it could be better im sure but it does make power and carry it all the way past 6700rpms...
you have any idea as to what 2 step i should go with? which one will work with my setup? im running the delteq coil on plug setup...
oh for sure just need to get out there more. just sucks cause our track down here is probably one of the worst prepped tracks around and its always packed.
my .02 cents. get that thing tuned for real. after tuning on mine for a month (only a few hours on the weekends, mind you) i cant see a mail order tune being even close to right. it might give you a starting point but nothing more. did you atleast have the wideband hooked up on the dyno run and if so what were the readings thoughout the run? the real problem i see is in the ve tables at part throttle and closed throttle position. if that isnt right the car will wash the rings and bearings out or run too lean and produce tons of extra heat and risk buring a piston. good job so far just make sure you keep at it and finish it.
while a mail order tune isnt your best option, it is obviously doing well for you. assuming your car is running well (seems like it is based on those track and dyno numbers), then hold off on the dyno tune until you get tired of the way the car runs now and have a little play money. you will most likely see a gain from a vehicle specific dyno tune, maybe 5 rwhp, maybe 30 rwhp who's to say. either way that's a strong MFer. spend the money on visiting your track and learning that sucker
great numbers regardless. perfect example of an old LT1 still performing awesomely on somewhat of a budget.
