LE2 H/C Question
Old Apr 30, 2007 | 12:43 PM
LT1_King's Avatar
LE2 H/C Question
hey guys i have a stock rebuilt 355 LT1 with stock internals. i was wondering on a heads and cam package like the LE2 would i have to use bigger injectors? is it really necessary? i know i have to do all the bolt ons but i just was wondering if i HAD to go bigger. this is going into a 94Z A4 Camaro.
Old Apr 30, 2007 | 01:42 PM
MEAN LT1's Avatar
Some 30lb injectors should be fine unless you plan on sprayin.
Old Apr 30, 2007 | 01:52 PM
94/96ZsM6s's Avatar
on a N/A 355 you shouldn't have to upgrade injectors. just make sure the fuel system itself is in good shape(pump, filter, regulator and injectors). i know of a guy who took a 93 Z, stroked it to a 383 and put the stock heads untouched and 19pph injectors and it worked fine. the car sounded great. 94'Z's and up have 24pph injectors...you should be fine
Old Apr 30, 2007 | 02:26 PM
LT1_King's Avatar
i plan on spraying but not till about next year or so. i'm gonna do the build this summer. so should i stick with the 24's for now? how much do new fuel injectors run. say like accel. or is there a cheaper brand? i will probly spray a 100 shot with the H/C but thta's till next year.
Old Apr 30, 2007 | 03:43 PM
z28_theantirice's Avatar
Stay away from accel. Either way you look at it, you need bigger injectors for your head/cam combo, go get some Racetronix 36'ers and be done with it 300 bones
Old Apr 30, 2007 | 03:46 PM
TQdrivenws6's Avatar
Um...
I strongly disagree. It may have worked for your friend's 383, but an LE2 package needs SVO 30's at a minimum. Of course unless you want to run a significantly higher fuel pressure than factory to bandaid your injectors being undersize for the application.
Old Apr 30, 2007 | 04:42 PM
2000GTP's Avatar
On Lloyd's site, for that combo he recommends 30-36# injectors.
Old Apr 30, 2007 | 05:30 PM
Javier97Z28's Avatar
Moderator
And his car is probably another 13 second 383 LT1....
You need to step up to at least 30lb/hr injectors. That's what I'm running.
Old Apr 30, 2007 | 09:10 PM
mobleman's Avatar
I ran my LE2 heads with the stock injectors for a few weeks.. Swapped them out for some used 30# SVO injectors and really noticed a difference at higher rpm's. Unfortunately I don't have any datamaster runs before or after showing the difference in injector duty cycles at higher rpms..
Old Apr 30, 2007 | 11:09 PM
lt1chevelle's Avatar
i just ordered some 37lb for my le2 heads and gm847 combo, thats what loyd recommended and i think they were like 295 and some change
Old Apr 30, 2007 | 11:45 PM
JP95ZM6's Avatar
+1 for Racetronics.
Old May 1, 2007 | 01:51 AM
LT1_King's Avatar
cool. where's the cheapest place ot buy the racetronics.
Old May 1, 2007 | 06:13 AM
JP95ZM6's Avatar
Direct from them is the best I found, $280ish:
http://www.racetronix.com/621037.html
At 37#/h you have a little room to grow, and from what I read the Delphi/Lucas style has a good pattern and is resistant to fouling. Good luck.
mikey4play
Mar 15, 2015 11:45 AM
Bignasty85
Mar 3, 2015 04:05 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
alphaauto
Jan 22, 2015 08:02 PM
