LE2 guys cam surge?
Old Apr 29, 2008 | 05:40 PM
95z28_m6's Avatar
LE2 guys cam surge?
Do any of you guys running le2 heads and cam ever have a problem with cam surge at say light throttle, crusing at 1200rpm to 2000rpm? I just got this thing on the road and I cant really tell if it is a miss or just cam surge. And btw it pulls really hard and runs good at any real throttle.
Old Apr 29, 2008 | 07:41 PM
94zgreenmachine's Avatar
mail order tune?
Old Apr 29, 2008 | 08:18 PM
wrd1972's Avatar
Get a dyno tune, mail order tune wont cut it period.
It is running lean at those RPM's which causes most of the surge. The problem is if you run a closed loop tune, then its hard to get the PCM to add more gas within this range without affecting the rest of the RPM ranges. If you run a speed density tune then it can be tuned completely out. I encountered the same thing with my cam and I have two tunes to counter this problem.
Old Apr 29, 2008 | 10:38 PM
95z28_m6's Avatar
Well I guess I will just have to live with it for now. I am going bigger this winter and dont want to waste money on a dyno tune that will only be good for the summer.
Noenav
Mar 1, 2019 07:38 AM
AdsoYo
May 2, 2018 03:21 AM
mikey4play
Mar 15, 2015 11:45 AM
Red97LT1
Aug 7, 2002 05:45 PM
