LE2 combo, you run w/ or w/o stall?
Old Feb 3, 2005 | 10:40 PM
RansZ28's Avatar
If you have the LE2, do you run a stall or not?
How much of a difference in the HP is there?
Old Feb 3, 2005 | 11:11 PM
med_reject's Avatar
Re: LE2 combo, you run w/ or w/o stall?
a higher stall will result in less peak horsepower, but will keep you in a higher powerband during almost all of your acceleration. You'll also get less cam surge because the car will be revving higher at slower speeds. With a higher stall, you'll burn more fuel, and have a lower top speed (unless you have 2.73s which would be bad with that cam).
All in all, a higher stall will improve performance and driveability.
Old Feb 4, 2005 | 10:17 AM
RansZ28's Avatar
2600 or 3000 stall?
Old Feb 4, 2005 | 11:41 AM
sssalah's Avatar
Originally Posted by RansZ28
2600 or 3000 stall?
3000 without a question, I'm sorry I didn't go with 3600.
Old Feb 4, 2005 | 11:21 PM
DiabloGT's Avatar
i didnt think it would lose top speed? would it with 3.73's? and are 3600's bad for a stocker or no?
Old Feb 5, 2005 | 02:03 AM
med_reject's Avatar
you lose rwhp, which means the potential top speed is decreased.
Old Feb 5, 2005 | 10:34 AM
DiabloGT's Avatar
how much rwhp and how come?
Old Feb 5, 2005 | 11:36 AM
med_reject's Avatar
higher stall = more slippage = more drivetrain losses. Ive never dynoed before and after a stall, i think some people can chime in here. I would expect an extra 5-7% drivetrain loss with a 3000 stall.
Most people dont ever take their cars to top speed and are happy with gains in acceleration and improved 1/4 mile times.
Old Feb 5, 2005 | 11:52 AM
94zgreenmachine's Avatar
Depends on the stall. Some slip more than others especially the "off the shelf" stall converters. Yank, Precision Indusrties are a few to check into. A little pricier but definately worth the money if you want the most from your combo. Try edgeracingconverters.com They custom build for your application. I'll be getting a stall set around 3400-3600. These are 3 brands that Llyod Elliot has recommended looking at when I asked.
Old Feb 5, 2005 | 11:54 AM
Guess, I shouldn't have said depends on the stall. I meant the brand. You may need a tranny cooler for the smaller diameter stalls but any performance /high hp, tq car should have one anyhow. Lots of heat and thats not a good thing
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
CaRParts102
Dec 6, 2014 08:45 AM
thenewkid
Nov 29, 2014 04:54 PM
