LE2/4 Combo Finally Dyno'd
Old Jul 30, 2006 | 11:53 PM
  #16
OneFlyn95z28's Avatar
Re: LE2/4 Combo Finally Dyno'd
Nice numbers! Welocome to the club. we hope to actually tune mine soon
Old Jul 31, 2006 | 09:57 AM
  #17
RealQuick's Avatar
Nice #'s.
Old Aug 2, 2006 | 07:22 PM
  #18
SStrokerAce's Avatar
Killer numbers man.
It always amazes me that we put down some of the best numbers all these guys have seen for LT1's.
Bret
Old Aug 2, 2006 | 08:00 PM
  #19
Hybrid86Z's Avatar
Originally Posted by SStrokerAce
Killer numbers man.
Bret
we are going to be adding another one to the list pretty soon Bret. My LE ported AFR's and your cam are in the car now, and should be getting ready for the dyno tune friday or sat.
i'll let ya'll know what the numbers are :yup:
-Ben
PS. - thanks again Lloyd for helping me out w/ that problem i had w/ the 918 keepers in which i called you about yesterday.
Old Sep 8, 2006 | 12:00 AM
  #20
2fast97z's Avatar
waiting on my le4 cam to arrive right now car will be back together in 3-4 weeks and going straight to the dyno soon after break in
Old Sep 8, 2006 | 09:54 AM
  #21
klrz28's Avatar
what cam are you putting in your 383? mines a 383 lt4 upper end, i want to go bigger i have 230/236 .590/.603 112 lobe solid roller in it now, it doesnt hold the torque above 4650 it made 380rwtq whats the le4 cam specs ? where do i find one?
Old Sep 8, 2006 | 10:26 AM
  #22
OldSStroker's Avatar
Get the LE cams from Lloyd Elliott, Mr. LE himself. The specs are hermetically sealed in an old mayonaise jar on Funk and Wangalls' back porch and aren't published.
Old Sep 8, 2006 | 11:18 AM
  #23
The only way to get those is to send your heads to Lloyd Elliot and get a LE4 cam for your setup, then you'll know the cam specs. We don't give them out, and obviously the specs don't mean as much as the results.
Bret
Old Sep 8, 2006 | 11:57 AM
  #24
Shon Herron's Avatar
This is a 383/396 that put down 423 and that is the "nastiest LT1 on their rollers"?
Originally Posted by cmroSS97
Well took my car to Cartek for a dyno tune yesterday (those guys turn out some SERIOUS LS1's) my car put down 423rwhp and 410rwtq I though these were very good numbers considering i'm running 20w50 oil, and cats w/ a y-pipe and borla cat back,also i only had 18psi in my tires and also considering i ran out of fuel injector @ 5400 rpm , power started falling off at about 6000. Torque was over 400 from 2900 all the way till 5400. it was also very HOT inside the shop ( i know dyno corrects this but it isn't 100% accurate) so there is more to be had out of it. Very happy with the results and the guys at Cartek were stunned that an old LT1 can put that down, according to them it was the nastiest LT1 ever on their rollers ( n/a). Now for 42lb injectors, the tune to go with them, and then a little giggle gas.
Old Sep 8, 2006 | 03:04 PM
  #25
MEAN LT1's Avatar
They havent seen Brettinator's Car i see. lol
Old Sep 8, 2006 | 05:43 PM
  #26
Or see this one...
http://web.camaross.com/forums/showthread.php?t=470607
When a guy doesn't have everything worked out and he still makes 423rwhp @ 5400! there is a ton more in it when it peaks at 6200-6500rpm. That will really wake up Cartek.
Bret
Old Sep 18, 2006 | 09:07 AM
  #27
TAEnvy's Avatar
Do alkl the cubes really tame that cam or is it still pretty radical?
Henson071
Dec 30, 2015 09:55 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
nd4spd200
Aug 21, 2015 09:30 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
