LE2 383 Idle AF
Old Mar 6, 2006 | 11:02 PM
Deenasty's Avatar
LE2 383 Idle AF
Im running an LE2 383, with a Innovate Wideband right after the cat and Im registering mid 14's at idle, but it STINKS! Serious, it stinks like fuel still. Also, the car doesnt seem to leave a stop smoothly. I am having to rev it up slightly to get it to go, otherwise it will buck. Any ideas?
Old Mar 6, 2006 | 11:17 PM
turbo_Z's Avatar
Re: LE2 383 Idle AF
2 problems.
The wideband needs to be BEFORE the cat in order to get a true reading of the AFR.
Also, You have to aim a little high(lean) to get in the 14.7:1 range because of the valve overlap with that large cam. In fact you could even run it a true 16:1 at idle and cruise with no trouble.
Old Mar 7, 2006 | 01:02 AM
Deenasty's Avatar
Re: LE2 383 Idle AF
I understand that the wideband should be before the cat, but someone told me that it would only skew the mixture about .2 Right now its showing 14.4-14.7 at idle. But it still smells and it doesnt come off of a stop too well.
Old Mar 7, 2006 | 09:16 AM
RealQuick's Avatar
Re: LE2 383 Idle AF
Minute differences in befoe and after the cat from my experience (marine industry). The differences in one of our small engines was .01-.02 lambda.
tnorm077
May 23, 2015 09:10 PM
Nutty's96
Parts Wanted
May 12, 2015 09:37 PM
Bignasty85
Mar 3, 2015 04:05 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
