le2 383 BRE cam track times.
Old May 25, 2008 | 01:27 PM
383racecar's Avatar
Just went 11.56@118.31 on motor full weight 1995 camaro bolt-ons ture duals. Went 10.13@135.91 on spary with only a 1.53-60ft..
Old May 25, 2008 | 01:30 PM
endobong's Avatar
Nice times, How much of a shot 150? Im assuming an auto?
Old May 25, 2008 | 01:59 PM
marshall93z's Avatar
Nice!
200 shot?
Old May 25, 2008 | 02:44 PM
383racecar's Avatar
A3 car with 225shot.
Old May 25, 2008 | 03:59 PM
MeanGreen97Z's Avatar
Now that's moving!
Old May 25, 2008 | 04:11 PM
user 647483's Avatar
Kickass
Old May 25, 2008 | 04:54 PM
383racecar's Avatar
thanks guys im going for 9s after some front QA1s..
Old May 25, 2008 | 05:28 PM
IEAT50Z's Avatar
mod list?
Old May 25, 2008 | 05:35 PM
The Engineer's Avatar
9s are good, however, they make drag racing much more complicated. For example; you’ll need an NHRA S/G license (7.50-9.99), chassis certification, full fire-suit, Etc.
WD
Old May 25, 2008 | 05:59 PM
Depends on where you run.
Old May 25, 2008 | 07:04 PM
And how foolish you are.
If you have a 9 sec car and you're running it without safety gear, you put your life at risk.
There's a reason those rules are in place.
Old May 25, 2008 | 07:16 PM
383racecar's Avatar
Originally Posted by IEAT50Z
mod list?
383lt1 srp pistons 11.7cr.BRE cam,le2heads intake,longtube headers 3inch true duals,CSR water pump,36injectors,58mmtb,255lph,mail order tune,3.73 8.5 diff,BTE 3800stall, stock susp. both times are on 93octane pump gas and foot braking it has a tci transbrake needs more tire...
Old May 25, 2008 | 07:18 PM
mdacton's Avatar
I would be alot less worried running 9.90's than I would 8.40's......
I bet hardly anyone at the track has a full suit running hi 9's.
Good job.
Old May 25, 2008 | 10:40 PM
mpe331lx's Avatar
Very impressive! What type of nozzle(s) sre you running (single, dual, or dirct port)?
Old May 26, 2008 | 08:08 AM
Z-RATED94's Avatar
I too, am curious about your nitrous set-up. GOOD TIMES!!!!!!!!!!!!!!!!!!!!!!!!
