le2 383
ITs a 1995 camaro with a th350 with trans brake stock suspenion with custom torque arm and lower control arms,3.73 gear 26-10 tire,all bolt ons ture duals,250shot. went mid 11s on h.p.
Are you running the nitrous off the same pump as the rest of the car(I assume your using a wet shot)? If so what sort of pump are you running and does the FP drop off in the upper RPM band? THX
I ask because I'm getting ready to run a 200 shot on my car off an in tank 255lph pump. I have the jetting and all for a 300 shot but am skeptical of running all that off the stock fuel lines/rail.
motor is sold, working on a new big inch sb setup but it was a 350 4 bolt .030 over, 6" scat h beam rods, 4340 crank scat also. all arp bolts, SRP 11cc dome pistons, 11.2:1 compression. AFR 210cc race readys the oldschool ones, 275cfm at .550 lift. solid flat tappet crane cam, 252/260 duration low 500 lift on a 1.6 making it mid 500. edelbrock vic jr. intake. she really liked the jug, made 520 crank hp n/a and 700 crank with a 150 pill and a empty bottle, surged out the next dyno pull lol.
