LE1 package coming soon
As the title states, my LE1 kit is coming soon and I can't wait. Hopefully it will be installed and finished by next weekend. The cam is already here (benefit of living in a suburb of Memphis) and it looks great. I already have all of the neccessary parts for install.
Such as:
Preform valve covers
Pro magnum rollers
Trickflow chromolly pushrods
Redtop 30# ford injectors
Pro products 58mm throttle body
Trickflow guideplates
Ls7 lifters
New timing chain
AARP rocker studs
All gaskets
will get header bolts and new tune this weekend
A couple other parts going in will be KBDD SFC's, a new oil pump with the white spring, and my poly motor mounts. Yes if you could not tell I am very excited. I will keep you posted and try to get track times when finished.
Such as:
Pro magnum rollers
Ls7 lifters
New timing chain
AARP rocker studs
All gaskets
your set up is very similar to mine, good luck with it
and be sure to check for contact between the bottom of the guideplates and pushrods, you may need to modify your guideplates slightly in order to work correctly, and dont forget thread sealant on the rocker studs
I'm getting it done at a shop. I know i'm lazy but I have never been that deep into a car engine. Besides I work on airplanes all day and the last thing I want to do at home is more work.
well not only did i have that problem but i know of at least four other people with trickflow guideplates that had that, so you may want to let them know there is a known problem with contact they should at least check for,
and yes, you are lazy
F'n1996Z28SS
Aug 23, 2023 11:19 PM
