le1 le2 le3 ai185 ai200 ?
Old Oct 18, 2007 | 09:42 PM
chevyrules85's Avatar
question is im looking for about 450 rwhp - current mods in sig = now where close.. so this brings me to a h/c swap and im wondering which i need to go with to get this kind of power... along with that i have now ill be getting bigger injectors bigger throttle body and porting the intake either by le or ai, also thinking about jumping up on displacement, so who makes a good 383 kit for the lt1 motor? preferably forged pistons anyways
Old Oct 18, 2007 | 10:01 PM
tireburnin's Avatar
Please do a search. I realize you're new to the board, but as a heads up these theads don't turn out well. Just search for past threads with similar titles.
Old Oct 19, 2007 | 03:01 AM
crushah's Avatar
I've heard good things about le, but i've opted to go with ai...http://advancedinduction.com/. I'm doing a 1200hp set-up, and ai will be doing the top-end...their h/c alone will get me at around 530-545 hp, and that's with around 8:1-8:5 comp.
Old Oct 19, 2007 | 05:44 AM
Schweet97Z's Avatar
both porters do top notch work. what you need to do is call and talk to both of them. i opted for lloyd and my car makes great power, but im looking to put the car in the 9's so its a toss up between the two for me also. time will tell.
Old Oct 19, 2007 | 07:31 AM
Vicious95Z28's Avatar
I was thinking the same thing as soon as I saw the title. The thought came to mind "Oh boy, another urinating contest"!
You'll have excellent results with either one you choose.
Old Oct 19, 2007 | 07:36 AM
What it takes to get 450HP at the rear wheels will depend on your drivetrain. Do you have an A4 or an M6?
Old Oct 19, 2007 | 07:48 AM
Javier97Z28's Avatar
Moderator
You've already been given alot of advice in your 10 second LT1 thread.
http://web.camaross.com/forums/showthread.php?t=548550
Old Oct 19, 2007 | 09:21 AM
96capricemgr's Avatar
450rwhp is possible even through a parasitic drivetrain, BUT is an unrealistic goal for an inexperianced builder/owner.
Cubes do not make HP, they can make HP more drivable but wont add it. HP is a function of airflow and everything above the block is what controls that.
I just have to shake my head when first it was a few guys hitting 400rwhp and then that became the standard and now more and more guys think 450 is just a matter of ordering a few part. These days 400rwhp is just a matter of the right parts and bolting it together right, 450rwhp is going to take a lot more knowledge and money at least to do it NA. You DO NOT need converted heads and a carbed intake as some would have you believe but it is still a lofty goal for most.
Old Oct 19, 2007 | 09:37 AM
RealQuick's Avatar
Care to explain what setup this will be?
Old Oct 19, 2007 | 09:39 AM
RealQuick's Avatar
I dont agree with you most of the time, but I agree with everything in this post
Old Oct 19, 2007 | 09:47 AM
dangalla's Avatar
i cant help but to feel like you been lied to, 545hp n/a with 8:1, ha good luck
Old Oct 19, 2007 | 10:16 AM
RealQuick's Avatar
This is the reason I asked bout details of his setup. If he is running an LTX... no freaking way. I know a local guy who has a 8.5:1 408 LSX (with a single plane intake) and he made 440rwhp on motor and 860rwhp @14psi with a T88. The 440rwhp is approximately 520fwhp.
Old Oct 19, 2007 | 11:38 AM
speed_demon24's Avatar
If hes going solid roller that's not a hard goat to obtain at all with the correct parts assuming its FWHP.
Old Oct 19, 2007 | 11:53 AM
dangalla's Avatar
really, even with 8:1 compression. seems quite lofty to me
Old Oct 19, 2007 | 11:56 AM
RealQuick's Avatar
Notice that all the SR guys making 450-475rwhp are ~11.5-12:1 CR... try those number with 8:1... I dont think it will happen.
