LE1 or LE2
Old Feb 8, 2005 | 04:22 PM
steves97z28's Avatar
LE1 or LE2
im doing a heads/cam set up, and cant decide which one to get. the LE2 will make more power yes, but when i rebuild, its gonna be a FI motor so ill most likely get new heads. so should i just get the LE1 package and not invest the extra money into the better heads? just looking for some opinions
Old Feb 8, 2005 | 05:23 PM
blackztpi's Avatar
Re: LE1 or LE2
le1 is more like a mix of a cc305 with stock heads, as far as power goes. go with le2
Old Feb 8, 2005 | 11:49 PM
SStrokerAce's Avatar
Re: LE1 or LE2
370rwhp vs. 390-400rwhp is that price difference worth it to you?
The setup later on will be worth more if you spend more, but it's still fractional.
Some of this depends on the time you have it too..... if you are going thru the work do you want all the power you can get doing the same work? 20-30rwhp is probably worth it.
BTW the cam is not just a CC305....
Bret
Old Feb 8, 2005 | 11:53 PM
SS MPSTR's Avatar
Re: LE1 or LE2
The CC305 is a little tamer and an older, albeit successful with the right application, grind.
Old Feb 9, 2005 | 09:01 AM
Re: LE1 or LE2
power is important, but its a big price diff. and i plan on building a blower motor in the future so i dontknow if its worth the extra $$$$$$$$$
Old Feb 9, 2005 | 09:40 AM
SS MPSTR's Avatar
Re: LE1 or LE2
Gotta pay to play.
Old Feb 9, 2005 | 09:42 AM
TRICK95's Avatar
Re: LE1 or LE2
Hell, I'd shoot Lloyd an email and see if that helps ya any. To me, his LE1 kit is sounding pretty sweet for the price, LE2, I don't know, I guess it really depends...
Old Feb 9, 2005 | 01:22 PM
jcolez28's Avatar
Re: LE1 or LE2
I think there is a 1.5 kit that is cheaper but is the same port job. Check that out.
Old Feb 9, 2005 | 01:24 PM
Bersaglieri's Avatar
Re: LE1 or LE2
Pretty sure the 1.5 is LE1 heads and LE2 cam. A nice inbetween combo.
-Dustin-
Old Feb 9, 2005 | 02:05 PM
1-bad-z28's Avatar
Re: LE1 or LE2
does he have a website?
Old Feb 9, 2005 | 02:08 PM
TQdrivenws6's Avatar
Re: LE1 or LE2
http://www.eportworks.com
Old Feb 9, 2005 | 02:15 PM
1-bad-z28's Avatar
Re: LE1 or LE2
wow!!!!! those are some damn good prices. That is unbelievable hp #'s for such few mods. No wonder why he has gotten so popular so quick
Old Feb 10, 2005 | 12:14 PM
jcolez28's Avatar
Re: LE1 or LE2
I think the 1.5 is the same heads as the LE2 with different valves and retainers and the LE2 cam. Check it out thoughretainers
Old Feb 10, 2005 | 01:24 PM
Re: LE1 or LE2
ya, im just gonna order the LE1 this week, the LE2 is gonna require a bigger throttle body and the manifold should have work so its gonna add up real fast. ill just get the LE1/spray while a build up a new motor
Old May 21, 2006 | 04:35 PM
user 647483's Avatar
Re: LE1 or LE2
And apprently pretty accurate.
Most of the people who've had it done have nothing but great things to say.
and their dyno numbers are well within the estimates. I don't think I've actually read any negative reviews on Lloyd and Bret's work.
9t4lt4z28
Oct 2, 2015 10:28 AM
Schul365
Aug 25, 2015 05:47 PM
ShawnMacAnanny
Dec 15, 2004 06:22 PM
Mystic97Z
Nov 1, 2004 11:24 PM
Mystic97Z
Oct 16, 2004 11:07 PM
