le1 with a 355?
Old Mar 21, 2005 | 07:52 PM
Inutero's Avatar
le1 with a 355?
would this be a good combo? I dont want to make insane numbers, so I'm not too worried about stroking it. Maybe in the 410-420 hp range (at flywheel) and a low 12 sec 1/4?
I just spun a bearing, so I am considering rebuild options.
Old Mar 21, 2005 | 08:17 PM
Pasky's Avatar
Re: le1 with a 355?
Pretty sure it would be a 12 sec car. Im going LE1 on my 383.
Old Mar 21, 2005 | 08:27 PM
ulakovic22's Avatar
Re: le1 with a 355?
You can easily make those numbers with the LE1 package in a 355. Once my combo gets all the bugs worked out and broken in I will head to the dyno. Hopefully I will be around 370 rwhp after it's all said and done.
Inutero's Avatar
Re: le1 with a 355?
How much would everything cost? anyone have a ballpark estimate?
Old Mar 21, 2005 | 08:34 PM
jchevy's Avatar
Re: le1 with a 355?
I just spent about $1800 and i already had the rockers, lifters, and timing set.
LE1 package - $1200
Larger valves for the heads - $200
gaskets - $130
30# injectors - $150
52mm tb - $150
Dont forget all the other little things like oil and coolant and whatnot.
Old Mar 21, 2005 | 10:07 PM
SStrokerAce's Avatar
Re: le1 with a 355?
You might want to go LE1.5 then, a LE1 head and LE2 cam. Or just step up to the LE2 package.
Bret
Old Mar 22, 2005 | 03:32 AM
Inutero's Avatar
Re: le1 with a 355?
LE1 package - $1200
gaskets - $130
52mm tb - $150
Well I would like to know the price for a normal 350 block..... Machine work, all the new parts (pistons, rods, bearings, blah blah)
I could use my old crank as long as I am not going forged, right?
Old Mar 22, 2005 | 03:36 AM
Re: le1 with a 355?
For a 355 the stock crank will work awesome.
I would use some Eagle or Scat I beams $230-$250 and some Mahle or SRP pistons and Rings $560, gotta find a core first and machine work is usually around $700 bucks and then assembly.
Bret
Old Mar 22, 2005 | 06:38 PM
Inutero's Avatar
Re: le1 with a 355?
Could I hit 11's with this setup? I would also have pacesetter LT's, electric WP, SLP CAI, and probably a dyno tune.
Old Mar 22, 2005 | 07:30 PM
Re: le1 with a 355?
400rwhp and 3500lbs has the power for 11's, just need the traction.
Old Mar 22, 2005 | 08:15 PM
ZDriver96's Avatar
Re: le1 with a 355?
be super careful putting it together and do everything by the book or you'll spin another bearing after the rebuild.
LE1 heads kick ***. you'll like em.
Old Mar 28, 2005 | 04:17 PM
Inutero's Avatar
Re: le1 with a 355?
Well I would probably have a shop put it together. I have decided to reuse my crank and rods, so I will need some good budget pistons. I dont care about forged, I will not be running nitrous (in the slight possibility I do, it would be something small like a 75 shot). What are some decent pistons?
Old Mar 28, 2005 | 05:13 PM
ZDriver96's Avatar
Re: le1 with a 355?
keith black pistons have good reviews.
I bought my forged Eagle SIR rods for 170 bucks on ebay. Nice pieces.
Old Mar 29, 2005 | 02:26 AM
Inutero's Avatar
Re: le1 with a 355?
I have a question. What would be the gain difference of going with a 355 over just rebuilding the engine to 350 and putting the LE2 on it?
Old Mar 29, 2005 | 02:35 AM
Silvershark's Avatar
Re: le1 with a 355?
From a 350 to a 355 you will not see any performance increase. You will only see an increase in hp/torque if you go to a 383. Usually people go to a 355 becuase its easier to get pistons etc for a .030 over bore. The power is in the heads cam etc. Click on my link below. Go under specificatons. That's what my motor consists of. I am hoping for a 400rwhp+ car.
