LCA question
Old Feb 3, 2004 | 08:24 PM
RedHottG2's Avatar
LCA question
I have had a problem for awile now with a loud noise comming from the rear of my car and I put it on a lift today and discovered my driver side lower control arm was really loose. When I hit it on the sides, it would move from side to side . The other side seemed to still be alright. My question is when I got to replace my LCA's (BMR), should I replace my uppers also or if they are ok, will it be fine? Thanks for your help guys .
Old Feb 3, 2004 | 08:33 PM
Spinner's Avatar
There are no upper LCAs that I know of?
Or maybe im mistaken.
Are you talking about the A-Arms in the front?
Old Feb 3, 2004 | 08:35 PM
93Z286Speed's Avatar
there are no upper control arms in the rear, we dont have a 4 link set up.. basically we have a "2 link" set up
Z95m6's Avatar
there are no upper control arms on the back.
Old Feb 3, 2004 | 08:38 PM
RedHottG2's Avatar
hmm...well I might be wrong about the upper control arms. I don't know that much about suspension. All I do know is that my driver side LCA is trashed on the driver side rear. Anyone else know anything about this ?
Old Feb 3, 2004 | 08:39 PM
Spinner's Avatar
Old bushing probably tore, or wore away. A new set should remedy the problem.
RedHottG2's Avatar
Thanks guys...I posted with out getting to read all the posts before hand. That clears it up for me. Thanks for the info!!
lbrowne
Nov 13, 2011 04:25 PM
Brad 97z
Aug 10, 2002 09:58 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
