Last minute tips, advice, etc before starting new motor...
Old Apr 23, 2003 | 08:27 PM
96z's Avatar
96z
I plan on starting the new stroker up in the next couple days and I was wondering if you guys could give me a couple last minute double checks, tips, advice, things to make sure of etc....before we finally fire it up.
For example in hindsight has there been anything you have forgotten, should have done, etc when firing a motor for the first time?
Old Apr 23, 2003 | 09:19 PM
Ken95Z28's Avatar
Make sure the oil pressure comes up before you start it. (Hopefully you primed it before this stage) I just made sure I had oil pressure before I started it.
I also made sure I got fuel pressure up to the fuel rails before I started it.
Other than that turn the key and pray that you got everything tight.
Old Apr 23, 2003 | 09:52 PM
96z's Avatar
96z
Ken, we are going to prime the motor with the intake off, and then put it on, Ill also make sure I got some fuel in the rails....I hope I have everything tight.
Old Apr 24, 2003 | 12:06 AM
Prince's Avatar
I tend to do the sign of the cross in front of the car, then I give alittle nod to the auto gods for safe measure.
BTW, Lemme know when you plan on firing that beast up.
Dave
Old Apr 24, 2003 | 12:35 AM
chasmanz28's Avatar
Dave
nothing like that rush you get right before cranking the engine
Old Apr 24, 2003 | 11:18 AM
96z's Avatar
96z
Dave
Dave well be doing it monday from the way things look. Ill defenitly let you know for sure when it gets closer...along with the sign of the cross we should probably hold hands and maybe say a couple prayers.
Old Apr 24, 2003 | 11:23 AM
sitdownshutupholdon's Avatar
Yeah, you need to have Bret crack one of those Molson's over the rear fender like they do w/ champagne bottles for a ships maiden voyage
Make a check list and make sure you remembered to fill all the fluids. Also, fill up the big radiator hose w/ antifreeze when you're adding the antifreeze. I forgot about this once and the antifreeze wasn't circulating when I started it up so the temp gauge shot up.
Good luck Matt, wish I could be there to witness it but I have a bachelor party in Philly to go to this weekend.
Mark
Old Apr 24, 2003 | 01:44 PM
White Z 4 Show's Avatar
Safety first....some sort of water outlet? Have a waterhose ready. Be ready for anything!
Make sure the throttle cable isn't sticking, don't want to see how long that new 383 will redline.
Now breathe in, then breathe out, now breathe in, and then breathe out. Common do it. Now turn the key and pray to the gods your car likes your new engine and they start getting along!
Scottyboy
Feb 11, 2015 10:28 PM
Jan 23, 2015 01:13 PM
David Dorris
Jan 17, 2015 08:10 PM
HCz28
Jan 11, 2015 11:21 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
