Last minute Header install Questions???
Old May 9, 2004 | 04:23 PM
Got-LT1?'s Avatar
Hey all,
Im about to install my JET-HOT LTs with Hooker Y-pipe. I think I have all the accessories for the install, but i just wanted to know what I will need to connect my Borla Cat-back to the Y-pipe with out a cat? I know i will have to scrap some of the borla tubing because its not exactly 3 inches at the end, but does anyone know what length of tube i will need or if it will need to have any bends in it?
Thanks for the help,
Matt
Old May 9, 2004 | 05:47 PM
Got-LT1?'s Avatar
anyone?
Old May 9, 2004 | 06:49 PM
Spinner's Avatar
The Y- pipe should come out farther rearward then the factory Y-pipe. The borla will probably need 5-6 inches cut out of the intermediate pipe, and should fit right up to the Y
Old May 9, 2004 | 07:37 PM
Got-LT1?'s Avatar
that would be ideal!
Old May 11, 2004 | 11:07 AM
HK45's Avatar
My hooker Y pipe came with the 4 spacers to lower the crossmember but it didnt come with the longer bolts. Check yours to see if they're included. If not, autozone has them on the shelf.
Old May 11, 2004 | 11:20 AM
ppmz28's Avatar
take it to a muffler shop and letting them weld and bend the pipe... much safer
Old May 11, 2004 | 11:56 AM
Riddlerlt1's Avatar
mine also didnt come with longer bolts. it came with some bolts (not the ones for the ypipe collectors) but they werent long enough. I was kinda curious as to what i was supposed to do. Are the ones at autozone made just for this application or just universal bolts?
Old May 11, 2004 | 04:15 PM
HK45's Avatar
I think mine came with 6 collector bolts that worked fine, 2 new collector gaskets, 4 spacers, and 3 clamps. I took the original bolts to autozone and matched them up to a 1.25X40mm bolt. They are on a turnstyle with many other bolts. See if they have a 1.50X40mm and that will work better because these 1.25's were a little shorter than they should be.
Noenav
Mar 1, 2019 07:38 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
Brent94Z
Mar 21, 2002 04:44 PM
