Large cams and ignition timing?
Large cams ... ie 224/236 lsa of 114 to be more specific
The question is, do larger cams such as this one "like" a little more ignition timing in the part throttle ranges??
I'm actually in the quest of a little more vacuum and figure that if these larger cams can tolerate or even thrive on more ignition timing than their stock counter parts .... I may be able to get enough vacuum to work my brakes like they were meant to be ...
Any thoughts appreciated
LWm
LWm
