Lane's true duals pics
I just got some pics of my setup with Pacesetters. I've got the full 3" setup and am at stock ride height. The first 4 pics are of the stock exhaust, and the last 3 are of the true duals. This should give you guys a good idea of how much clearance you lose with true duals.
http://i2.photobucket.com/albums/y6/...Picture145.jpg
http://i2.photobucket.com/albums/y6/...Picture146.jpg
http://i2.photobucket.com/albums/y6/...Picture147.jpg
http://i2.photobucket.com/albums/y6/...Picture148.jpg
TD pics: First link is of the mufflers.
http://i2.photobucket.com/albums/y6/...Picture169.jpg
http://i2.photobucket.com/albums/y6/...Picture170.jpg
http://i2.photobucket.com/albums/y6/...Picture171.jpg
Overall I'm impressed with how well mine tucked up. The front on the driver's side is a little low, but not enough to scrape. I didn't get any pics of the system before I put it on, but it comes fully welded, very high quality with clean welds and good clamps, and it slid right over the headers with no problems. I highly recommend Lane's setup. He custom builds his kits, so there's no adjusting or tweaking necessary.
www.lanesperformance.com
Jason
www.lanesperformance.comJason
Re: Lane's true duals pics
Originally Posted by eagleknight97
What car is this for? The one in your sig?
LT1s are lower stocki woulda guessed it would be for a jeep wrangler cause of that ride height! i dont think i could have ever fit a can under my car practically
The car is the one in my sig, not jacked up or anything, and no I can't fit under the car unless it's jacked up but the camcorder/camera can.
The Mountain Dew I stole from a friend to take the pics, just for all you guys to see.
I've never heard of LS1's being higher than LT1's before. If so, it might be that LT1's are older and the springs are getting a little worn. My friend's 94 T/A sags slightly in the rear from age.
Jason
I've never heard of LS1's being higher than LT1's before. If so, it might be that LT1's are older and the springs are getting a little worn. My friend's 94 T/A sags slightly in the rear from age.Jason
