lacking power at WOT
Old Jun 12, 2007 | 09:41 PM
  #31
2QUIK6's Avatar
Originally Posted by ZL1modified
what type of scanner... cuz i have the scanner that tells you what is wrong when your check light comes on...
There are several laptop scan tools if you already have a laptop PC, I use DataMaster, its about $100 from http://www.akmcables.com/dss.htm
Or you can get a standalone scan tool lie a ScanMaster http://www.fullthrottlespeed.com/itemdesc~CartId~{AD2583FD-3E55-EVEREST457B-8629-216FA52AFC54}~ic~050SCANLT1~eq~~Tp~.htm
The laptop scan tool can record and playback. The Scanmaster only holds your highest and lowest readings.
Scan tool can display any sensor values that are input to the PCM...TPS, O2, IAC, IAT, timing, BLMs, INT, O2 cross-counts(tells you when the o2 is getting lazy)..and it goes on and on.
Old Jun 13, 2007 | 07:15 AM
  #32
ZL1modified's Avatar
here is the one i have... i did some reading on it last night and it looks like it will test the o2's with the car running...
http://www.sjdiscounttools.com/actcp9180.html
Nellsw88
May 27, 2015 10:27 PM
ad356
Apr 11, 2015 10:30 PM
jayblev95
Jan 20, 2015 01:30 PM
XtremeLt1
Sep 13, 2002 08:50 PM
Brian Demeter
Aug 17, 2002 08:07 PM
