lacking power at WOT
Old Jun 11, 2007 | 03:50 PM
  #16
Gripenfelter's Avatar
I'm going to guess fuel pump or clogged fuel filter.
Old Jun 11, 2007 | 04:10 PM
  #17
ZL1modified's Avatar
this could be why my first set went bad... the new o2's were put on way after the headers...
Originally Posted by JoeliusZ28
are your headers coated and if so did you install them? coated headers need to be properly heat cycled when installed BEFORE you put the new 02 sensors in or else the fumes from the coating will ruin them. I heat cycled mine at least 6 times and drove the car twice without 02s before I put my new sensors in.
new filter and new pump... i have repaced just about everything on this car (everything except injectors and the ecm)
what about the new non traction throttle cable that i installed... could that be a culprit(sp)?
as for now i'm going to check fuel pressure @ wot...
Old Jun 11, 2007 | 06:22 PM
  #18
JoeliusZ28's Avatar
Originally Posted by ZL1modified
this could be why
yep thats why the first set failed.
Old Jun 11, 2007 | 07:02 PM
  #19
update:
fuel pressure @ WOT is 50 psi (40 psi @ idle) and my pressure bleeds down instantly when i turm my engine off...(i thought it was to slowly bleed down)
Old Jun 11, 2007 | 09:06 PM
  #20
2QUIK6's Avatar
update:
Then I bet you are running pig rich, fp should be around 40-42 at WOT, same as if you unhooked the vac line going to the regulator at idle...thats because at WOT there is very little vacuum.
The "tune" does not know the fp, so its programmed based on a 40-42# fp.
Old Jun 12, 2007 | 06:51 AM
  #21
how do i fix it... where do i start?
i guess the pump is good... should i just try to turn the pressure down on my regulator? or should i just get rid of the adjustable one and go back to the factory FPR...
Old Jun 12, 2007 | 09:14 AM
  #22
2QUIK6's Avatar
Yes, if its adj, turn the pressure down. Any reason it was turned up that high to begin with?
Hook up a gauge to the fuel rail, unplug the vacuum line going to the regulator and set the fp to 42# then reconnect teh vac line and see how that works for you.
Old Jun 12, 2007 | 10:27 AM
  #23
oh thats nothing. when i first installed the aeromotive regulator it was on 60 psi...
i adjusted it but missed the whole part about the vacuum line needing to be disconnected... so it was my own stupidity and ignorance...
thanks for your help...
Old Jun 12, 2007 | 12:16 PM
  #24
2QUIK6's Avatar
One last thing, once you lower that fp, disconnect the battery for a few seconds and then drive it around a bit before going WOT, that way it gives the PCM a chance to "relearn" and readjust the BLM values....again, the last BLM value the computer was seeing before entering WOT/PE mode it will use to further adjust fueling during PE mode along with the additional fuel programmed in the PCM in the PE mode fueling table.
Old Jun 12, 2007 | 04:28 PM
  #25
ok, i set my fuel pressure to 43 with vacuum line removed...
now when i reattached the line it fell to 35...???
is 35 ok????
Old Jun 12, 2007 | 04:31 PM
  #26
SnakeSkinner28's Avatar
If when your done with all the fuel and electronic work and if it still has the problem you might want to look at your cats. If they are going bad because you were running so rich that will definatly cause power loss at WOT and if vapor lock sets in can make it harder to start as well. And most of the time, a bad cat will not trigger a SES light.
Old Jun 12, 2007 | 05:23 PM
  #27
mcalus's Avatar
I have a really dumb question...What does WOT stand for?
Thanks...
Old Jun 12, 2007 | 05:31 PM
  #28
2QUIK6's Avatar
is 35 ok????
yep...the more vacuum your motor pulls the lower the fp will become at idle with the vac line connected...at idle its pulling the most vacuum...beside coasting down a hill and you dodn't need much fuel for either...
If you had a scanner you would have seen your BLM (block learn multipliers) all whacked and wayyyy off of 128 and would have known something was wrong.
Old Jun 12, 2007 | 05:32 PM
  #29
2QUIK6's Avatar
Thanks...
Wide Open Throttle...the thing that puts a smile on your face
Old Jun 12, 2007 | 06:28 PM
  #30
what type of scanner... cuz i have the scanner that tells you what is wrong when your check light comes on...
