Lack of power at low rpm's.
Old Jul 22, 2004 | 12:25 PM
Pasky's Avatar
Ok, everything is running fine with the car until about 2 days ago. Im getting a off and on somewhat eratic idle, its not so much to the point that it will die, but it does make it sound like the car is loping, it comes off and on when the car is hot or cold. If I floor the car from any gear, it will kinda of sputter for a mere half second or so before taking off and then everything is fine. Im thinking I have some spark arc because I saw some wires were burnt a little from the headers. Anything else I should check out or is this a symptom of sparks arcing? Thanks.
Old Jul 22, 2004 | 04:03 PM
aintno6's Avatar
Re: Lack of power at low rpm's.
well if you wires are damaged, then they will need to be relplaced. This will cause all of the above issues you are getting. You mine as well replace the plugs while your at it, if they are due.
Replace the wires, be sure they arent making contact with the headers/manifolds. Start her up. If it runs good, then problem solved. If it runs bad still. Continue troubleshooting. For me, changing out my front o2 sensors cured my idle issues.
Good Luck,
Mike
Old Jul 22, 2004 | 04:08 PM
Pasky's Avatar
O2's are one month old, plugs are 2 and so are the wires. Replaced the opti two months ago as well. Im guess its the plugs but was just curious as to what else to check out this weekend. It doesn't seem to happen when the rpm's climb, just sudden hesitation when going WOT from low rpm.
Old Jul 22, 2004 | 04:58 PM
95BlackTA's Avatar
Gotta be wires if opti is fine. My car was idleing really rough before, and I replaced the driver side wires, and it cured it. To this day I cant find any burn marks on the old wires, and they were only like 2 months old also. Go figure.
Do the driver side wires first, cause they are the easiest ofcourse....then do passenger.
Old Jul 22, 2004 | 05:00 PM
Pasky's Avatar
Bit different for me, as mine is in a thirdgen, both are easy . I'll just replace them all and see how it goes, thank you all for your input.
Old Jul 23, 2004 | 09:13 AM
aintno6's Avatar
Well regardless you need to pull those wires that made contact with the headers. Even if it didnt burn all the way through. Some how it will still go and arc off the headers. I didnt think so, but when I cut into the wire I pulled off, I noticed traces of where it was actually arcing.
You can also take a look at the fuel filter as well.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
