Kooks stepped LTs vs. shorties...dyno results..
Re: Kooks stepped LTs vs. shorties...dyno results..
Originally Posted by 93redBirdMan
just for your information, the "ram air" effect is a myth. There is not air being "rammed" into your intake with ram air. It is just a good way to get cold air. with that being said, you would not be any faster at the track because of ram air. I read a huge post about this from fbody.com
Here is a link to a good post, but this isnt the link i was talkin bout...
http://www.fbody.com/cgi-bin/anythin...=804695#804695
I'll call it getting more cool air then...Anyway, historically, with this dyno, cars trap 2 mph slower than at the track...getting more air may have nothing to do with it. It could just be a software thing. Either way, the test repeatedly showed a .2 / 2 mph improvement over the shorties, but only the track will tell for sure...
--Alan
--Alan
I believe that the Kooks made the car faster
because of the simple fact that the
easier it is for the engine to breathe,
the faster you're gonna be.
And as for the "ram air debate",
cars do dyno slightly higher
when the air inlet is isolated(cooler
than under hood) and a straight shot
into the engine.
into the engine.
Well, my butt dyno says its faster...Its got wicked mid and top end. And it sounds a little different than before. Someone had said once that LTs and Borlas don't sound too good and I think they are right to an extent. Its got a slightly different note to it and I'm not sure I like it yet. WOT is wicked, idle is also wicked, but part throttle cruising has some weird spots that are hard to explain...
--Alan
--Alan
Interesting that I should run into this post. I came on here looking for info on this same subject. I too am considering switching from SLP shorties to a long tube header. I think you're probably the first person I've seen post before/after results.
My combo consists of a heads/cam, stock bottom end package, so I suspect I wouldn't benefit from a longtube upgrade the way a stroker would. These are very interesting results. Thanks alot for sharing it with us.
big dave...The SLP shorties are 1 3/4" right? Then I guess you would not see enough gain to warrant the change. I had 1 5/8" shorties and a 2 1/2" Y-pipe which is why I expected to see something. The back to back 1/4 mile dyno blasts were very interesting, though. My non calibrated butt dyno says theres a gain, but that could be wishful thinking. We'll see at Capitol one of these Friday nights...Joe Overton was very confident that these things would make a substantial difference at the track. I am hoping for 11.20s at 120. I know I got 9-10 rwhp with the EWP mod, so we'll see what we see...
--Alan
--Alan
--Alan
--Alan
I've gotten pretty bored with what I have now and I am actually considering a new combo that would possibly benefit from longtubes. I have a procharger that's been sitting in the closet fr the last few years.Even with the high compression I may be able to make the motor live long enough for a couple low 11 second passes. lol
Thanks, yeah its a pretty good combination of street and strip and durability. Thinking about it again I may have gone a wee bit bigger on the cam (current is a 226/234) but its got tons of throttle response and good mph. If I can get 11.20s out of it now, then I'll whittle away some weight to get a 10.9999 somehow...
--Alan
--Alan
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
