help with 94 LT1 coolant leak(rear of motor)
Old Apr 3, 2006 | 02:03 PM
black&red94Z's Avatar
I just finished a bunch of searches to see what I'm dealing with.
It doesn't look good.
I have coolant leaking out of the rear of the motor somewhere.
From what the searches tell me it's either a freeze plug, knock sensor, or the
hose that connects to the heads?
I am about to go out and try to find out for sure what it is.
My question is, any advice and or troubleshooting tips to give me for my search?
Anything else I should check while I'm under there?
thanks for your help guys.
Old Apr 3, 2006 | 02:05 PM
6SpdLT1Z's Avatar
Re: help with 94 LT1 coolant leak(rear of motor)
Originally Posted by black&red94Z
the hose that connects to the heads?
that was going to be my guess.. no real tips, do they make a coolant leak test or w/e?
Old Apr 3, 2006 | 03:08 PM
sabre81's Avatar
If the leak is coming from the back, it is most likely the steam pipe o-ring seals on the back of the heads.
Old Apr 3, 2006 | 03:29 PM
Javier97Z28's Avatar
Moderator
I 3rd that
calaban
May 18, 2020 06:43 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
