Koni or Bilstein or KYB or ???
Old Mar 12, 2004 | 10:00 AM
MarauderZ28's Avatar
Hi, I would like to buy some really good dampers (to use it for streetrace + drag).
Now I know about 4 possibilities:
1, Koni single adjusted
2, Koni double adjusted
3, Bilstein (I'm not sure what type)
4, KYB - AGX
Which one should I choose?
Are there any other, better dampers?
Thanx Marauder
Old Mar 12, 2004 | 10:18 AM
americanmusscle's Avatar
I decided on the Bilstein HD's and no probs so far.
Old Mar 12, 2004 | 10:21 AM
Hyperspeed97z28's Avatar
I'm going with those as well !!
Only shocks to come with lifetime warrenty
Old Mar 12, 2004 | 11:35 AM
GREGG 97Z's Avatar
I believe the best drag shock would be HAL's, also the most expensive though of course.
Old Mar 12, 2004 | 12:11 PM
chasmanz28's Avatar
best bang for the buck bilstein's for sure
Old Mar 12, 2004 | 12:22 PM
bad1LEz's Avatar
Bilstein HD's solved alot of my problems.
Old Mar 12, 2004 | 12:38 PM
I can't find Bilstein HD's. I have found these only (http://www.slponline.com/view_produc...RTNUMBER=70008), is that right?
Is there any online shop, where I can buy Bilsteins HD ?
Thanx Marauder
Old Mar 12, 2004 | 12:45 PM
Check out ebay, the slp ones are different..
I've seen the HD's on ebay quite a few times for 200 something...
Old Mar 12, 2004 | 01:46 PM
What about this kit?
http://www.slponline.com/view_produc...RTNUMBER=70001
Old Mar 12, 2004 | 02:47 PM
jtk's Avatar
jtk
the edelbrocks seem to be good
Old Mar 13, 2004 | 01:29 AM
RedPhenx's Avatar
go to stranoparts.com and get the number, sam will steer you in the right direction
Old Mar 13, 2004 | 02:12 AM
chasmanz28's Avatar
Thanx Marauder
http://www.bimmerparts.com/
JJOHNROE
Sep 8, 2015 05:39 PM
KYWes
Aug 10, 2015 07:03 PM
camaro98_speed
Apr 22, 2015 11:26 AM
SpikeLS1
Aug 30, 2002 11:38 AM
