Know any good tricks to get a rotor off?
Old Apr 24, 2003 | 07:02 PM
  #16
Mizz96Z28's Avatar
consensus is...
BFH!!
Old Sep 9, 2004 | 09:42 PM
  #17
Z28barnett's Avatar
Re: Know any good tricks to get a rotor off?
I had this problem with one of my rear rotors. The rotor was 90k miles orginal and rusted tight
A hammer failed for two hours and I wasn't looking to reuse the rotor, so I really hit it.
The fix, a Walmart "Mapp" gas torch. Mapp burns hotter than propane about 2000deg hotter.
I just held the torch for about 30 sec on the rotor center between each of the five studs. Aobut 2.5 minutes later two light taps and the rotor fell off.
A thin coat of anti-sieze will stop this from happening again.
Old Sep 9, 2004 | 10:23 PM
  #18
Originally Posted by chevyboy_z28
are u the original owner of the car, b/c if you are then chances are the passenger one was replaced because the factory ones are held on by studs in the back and when you change/clean them you dont have to put the studs back in.
in short...remove the studs from the back!
Where in the world did you come up with this?
Old Sep 9, 2004 | 11:13 PM
  #19
1fastlt1's Avatar
I would recomend if you are gonna be wacking it with the hammer that you either use a rubber malet or a piece of wood. It might be a good idea to spray some WD-40 around the studs and the center section. It may be a good idea to install a lug nut on a couple of turns so it doesn't fly off and land on the pavment and mess something up.
Old Sep 10, 2004 | 01:08 AM
  #20
Dave89IROC's Avatar
back from the dead
Old Sep 10, 2004 | 07:42 AM
  #21
Originally Posted by Dave89IROC
back from the dead
LOL, yeah!
BinkZ28
Apr 20, 2015 09:10 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
