Knocking with Vid
Old Jul 30, 2010 | 08:00 AM
  #16
95zsean's Avatar
Originally Posted by silverz28
I havn't drained the oil yet. Balancer looks ok.
GMHTP had a problem with a high knock count on their LT1 car and when they took the belt off to change the timing chain they realized it was the balancer loose. It had a underdriven pully system on it.
Old Jul 30, 2010 | 08:14 AM
  #17
razor02097's Avatar
I guess flexplate bolts next.
Old Jul 30, 2010 | 01:05 PM
  #18
SweetZRag's Avatar
Did you use a stethoscope or at least a screwdriver to the ear to isolate where it is coming from?
Old Jul 30, 2010 | 01:19 PM
  #19
silverz28's Avatar
I did listen with a screwdriver to the valve covers. It sounds like normal valve noise to me. I really don't like starting it up anymore, for fear more damage.
Old Jul 30, 2010 | 03:32 PM
  #20
silverz28's Avatar
I unbolted the torque converter and the flywheel is lose. You guys were right. Thanks for everyones help. Now I Gotta find some time to pull the trans.
Old Jul 30, 2010 | 05:06 PM
  #21
ray396's Avatar
Cool
Hi, I think if you unbolt the trans and slide it back, you can tighten the bolts. I have done it, it is tight. just my 2-cents.Ray
Old Jul 30, 2010 | 08:15 PM
  #22
lt1-xjs's Avatar
Auto 's don't have a flywheel, but we are glad you figured it out. Good call everyone.
Old Jul 30, 2010 | 08:35 PM
  #23
silverz28's Avatar
Flywheel, flexplate, whatever.
Old Jul 31, 2010 | 03:24 PM
  #24
TehFonz's Avatar
Dude my 93 383 is making the exact same noise as your video i thought it was a wrist pin or something and its been parked for a while, but I'm pulling it in the shop tonight to check the flexplate as well i really hope that's what it is because my engine only has 700 miles on it.
Old Jul 31, 2010 | 07:24 PM
  #25
96SSIndeed's Avatar
Maybe next time you'll work on it like i tell you to instead of parking it for a year wanting me to pull the motor.
Old Aug 1, 2010 | 01:35 PM
  #26
TehFonz's Avatar
hows about F*** YOu
Old Aug 1, 2010 | 04:23 PM
  #27
razor02097's Avatar
Old Aug 9, 2010 | 11:53 AM
  #28
siguy's Avatar
don't forget to put some lock tight on the bolts (would recommend ARP bolt while you are at it ) (also check the flex plate to see if the bolt holes were elongated if so you would need to replace the flex-plate ...)
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
