Knocking From Valve Cover Area...
Old May 27, 2003 | 09:03 AM
TDog's Avatar
Hi Guys...
Let me tell ya my most recent story...and hopefully you could give a little advice...
I just had a complete maintenance package performed on my '95 Z....
Opti, Plugs, Plug wires, Coil, Electric Water pump, Intake gaskets, valve gaskets, etc....
Got her back on Sat....run very strong...even put the z on the dyno...I was expecting 235 - 245 hp at the rear wheels...it's basically stock...However, I pushed out a 260 rwhp @ 5000 rpm on the first pull...and then a 265 rwhp @ 5000 rpm on the 2nd pull....
The tune up really put some pep in the stock Z...and I couldn't see any oil leaking out from anywhere...
However, this morning I noticed a knocking coming from under the hood...popped the hood and it sounds as if it's coming from the valve (valve cover) area...
It's pretty bad....especially when the accelerator is pressed...
Anyone got any IDEAS to what my problem is...I'm taking it back to the shop this evening for diagnostics...
Thanks,
TDOG
Old May 27, 2003 | 10:17 AM
TDog's Avatar
Any Ideas...
Old May 27, 2003 | 11:15 AM
InjectedSS's Avatar
check to see if a rocker came loose! did you take them off? if so did your readjust them properly?
Old May 27, 2003 | 01:46 PM
TDog's Avatar
I didn't do the work...Don't think the rockers should have been taken off...
Maybe should was hit or bumped...trash within...not sure...
Hopefully the shop that did the work will make good...
Any more thoughts....
T...
Old May 27, 2003 | 04:58 PM
BUBBA's Avatar
Just be sure that you have oil pressure before you drive it (1) foot.
If ok, then get thee to the mech. and have them figure it out. Stand right there and watch them do the diagnosis so they won't come up with some story about it being something else.JMHO
Old May 27, 2003 | 05:24 PM
Not really possible to diagnose over the 'net without a sound byte and still hard even with one.
HectorM52
Jul 30, 2017 11:46 AM
karnykamaro
Feb 2, 2015 01:37 PM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
