knocking under car
Old Jan 5, 2006 | 09:25 PM
97formula808's Avatar
knocking under car
i'm really not sure where this knocking is coming from. you can feel it hitting the floorboards. it usually happens as i'm coming off the gas. sometimes if i go to accelerate again slowly, ill get a knock. it usually happens when i'm at 50mph and i let off the gas and teh engine idles at 1.5K rpm and will knock consistently until i get back on teh gas or the off gas idle goes beneath 1.5K rpm. i recently installed prothane motor mounts, prothane tranny mount, and pacesetter headers. the headers seem to have good clearance. if i rev in neutral, no knocking happens. anyone have a clue to whats happening? its really frustrating.
Old Jan 5, 2006 | 09:28 PM
RICEFEDZ28's Avatar
Re: knocking under car
Is it an auto or a stick?
Old Jan 5, 2006 | 09:53 PM
sorry bout that A4
Old Jan 5, 2006 | 10:25 PM
RICEFEDZ28's Avatar
can you tell kinda what area that the noise comes from? Engine or trans area? Is oil pressure good? I had the same type of noise happen to me twice. Took my trans out and found I had crack my flex plate. The bolt holes in the center had crackes going all the way around. It had a thumping noise like a rotating sound. I thought at first it was something with the crank. But anyway i've cracked two of them so far and both times same sound. Its easy to take out the trans to. I changed my converter with a better stall to. If its out might as well upgrade.
Old Jan 5, 2006 | 11:07 PM
it seems to be coming from from between teh two front seats or by the foot wells. it hitting the floorboard amplifies the sound. did anyone have this symptom? this is really irritating. i dont think its the flexpipe as it hitting under the floorboard.
Old Jan 6, 2006 | 05:56 AM
RICEFEDZ28's Avatar
Is it more of a vibration or aknocking noise?
Old Jan 6, 2006 | 08:44 PM
its definately a knock
Old Jan 6, 2006 | 09:30 PM
walt355's Avatar
Check the tranny mount
Old Jan 6, 2006 | 11:05 PM
RICEFEDZ28's Avatar
If it's not the tranny mount i'm tellin ya check the flex plate.
Old Jan 6, 2006 | 11:18 PM
ttop1986's Avatar
couldnt a broken torque arm mount cause this too?
SpeedJunkee
Jan 27, 2015 10:02 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Lions3
Apr 11, 2003 10:55 AM
