Knocking, pinging, detonating, preignition, whatever...
Old Jun 16, 2003 | 08:21 PM
  #16
yorkie's Avatar
not sure
with the gasket there is no way it could be hitting, spun it up to 6300 rpms it is mainly when it goes into 2nd and a load is put on it.
Old Jun 16, 2003 | 09:35 PM
  #17
N2OpwrdTA's Avatar
Ill know how bad it was in a day or two. Waiting for the cherry picker to get here so i can take it out the top. Im pretty sure ive got some trashed pistons cause I drove it with detonation problems for so long. Im just putting in a whole new stock short block with stock ported heads and hotcam kit...then ill build up the current busted shortblock into a forged stroker...for when my new stock bottem end breaks. HOPEFULLY, getting rid of the detonation in the process.
Old Jun 16, 2003 | 09:37 PM
  #18
yorkie's Avatar
I just cant figure it out
There is guys running flat tops on 93 octane and this thing has dished.
Old Jun 16, 2003 | 09:40 PM
  #19
yorkie's Avatar
n2opoweredta, tell me what you have/had..
what motor components it had, pistons? Crank? Rods? Cam?etc...
When was it detonating? With a load, in 2nd? tell me about it please.
Old Jun 17, 2003 | 09:49 PM
  #20
yorkie's Avatar
putting a new double roller chain in, doubt...
that will help, but worth a try and a csi pump while I am in it.
Old Jun 17, 2003 | 09:54 PM
  #21
magius231's Avatar
whether it should need it or not, you need to try it. Forget the octane booster though, run unleaded race gas in there and see if it helps. If it does, my guess is the setup isn't quite what you thought it was...
Do a search, there has been a lot of talk about knock and stroker motors
Old Jun 17, 2003 | 09:57 PM
  #22
yorkie's Avatar
what do you do Hit search and put stroker knock?
Has -12cc pistons, what if compression is too high? Water injection?
Old Jun 17, 2003 | 10:15 PM
  #23
yorkie's Avatar
so what CR do I have approximately?
bore 4.030
stroke 3.75
connecting rod length 5.7
cylinder head volume 53 cc
deck has not been touched and was not measured.
head gasket bore 4.125
head gasket thickness .039
piston wall clearance .003
top ring land height .250
dish volume -12cc
Compression is?????
Old Jun 17, 2003 | 10:38 PM
  #24
Phatcaprice's Avatar
Maybe your knock sensor(s) are bad?
Old Jun 17, 2003 | 10:40 PM
  #25
yorkie's Avatar
has 1 and it is new.
you can hear it, it is like marbles in a tin can.
Old Jun 18, 2003 | 12:02 AM
  #26
yorkie's Avatar
I come up with under 11:1 so it can NOT...
be compression too high.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
