Knocking noise while AC inguaged
Old Jul 17, 2006 | 09:25 AM
kaoticcamaross's Avatar
The kocking nosie coming from my car has finally be located and I need a little advice. It only knock's when the ac is on and only at low rpms. I dunno if this is the ac's compressor bearings going out or if it is actually within the block its self. Can some one give me advice?
Old Jul 17, 2006 | 09:28 AM
Sweetred95ta's Avatar
Re: Knocking noise while AC inguaged
Are you sure it's not just the AC compressor being engaged? Do you have a aldl cable and anyway to monitor the car with Freescan? That would tell you if you are getting any knock retard (because the car is detonating).
Old Jul 17, 2006 | 09:34 AM
no i don;t have the cable or a way to monitor it freescan. So what should I do?
Old Jul 17, 2006 | 09:35 AM
And it's not just the AC being ingauged I don't tihnk because would that just stop once turned on? This seams to fade in an out
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
autoxr166
Sep 25, 2015 04:21 PM
SEOJustin
Sep 24, 2015 04:39 PM
