knocking after swap!!!!!
Old Jun 27, 2006 | 12:02 PM
DontMixWithRice's Avatar
my 96 obd1 lt1 is knocking out of the passengar side valve cover. im thinking its coming from a lifter.
what should i check to diagnose it better? the ticking sound is coming at higher rpms, and its very evident in fourth gear.
any thoughts?
Old Jun 27, 2006 | 01:00 PM
yotaman96's Avatar
Re: knocking after swap!!!!!
What kind of rockers are you using? They could be hitting the valve cover or may just be loose. Loose rockers will be loud.
Old Jun 27, 2006 | 01:14 PM
scrmnws6's Avatar
Check your valve cover. When I installed my LE2 setup, I had the rockers hit the valve covers, so I had to grind a little. But mine were not stock covers either, so just check.
Old Jun 27, 2006 | 01:49 PM
well first off, thanks guys.
ive had the engine in for a while maybe 6 months, and now is when i notice the ticking noise worsening. its a stock lt1...heads and all are stock.
i havent checked under the valve covers yet, and im not sure what to look for. im sure ill see one of them out of place or a bit elevated.
other than that...whats teh worst case scenario?
Old Jun 27, 2006 | 01:52 PM
valter's Avatar
Loose rocker / collapsed lifter. Pull valve cover, check all rockers.
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
whitehooptie
Aug 10, 2015 07:02 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Jocofire1
Aug 7, 2015 03:16 PM
Boss002
Jul 24, 2015 10:47 AM
