Knock on startup?
Old Sep 5, 2011 | 12:30 PM
Ricardo's Avatar
Knock on startup?
When I start my car, I sometimes get a small knock. It'll sound like..
Crank crank knock VROOOOOOOM idle idle idle
The engine runs like butter though. No stumble, no misses right through the power band and nothing else to complain about. I only get this knock on startup, and even then it's only sometimes. Any ideas?
I found this very old thread doing a search. There were some mixed opinions there and I wanted to give it a fresh start. The knock I am refering to is not a rod knock or a lifter tick or piston slap. Its like dieseling but the engine starts inmediately and idles smooth. No codes and no knock from the sensor.
It only does it with the engine hot.
Old Sep 5, 2011 | 12:36 PM
bw_hunter's Avatar
Re: Knock on startup?
Did you change fuel recently? Or did you fuel change?
Old Sep 5, 2011 | 12:50 PM
Ricardo's Avatar
No changes in fuel. 93 or better octane rating.
Old Sep 5, 2011 | 03:06 PM
Sounds like there may be a bit too much ignition advance for the "start" mode part of the tune.
Nayr
Mar 3, 2023 08:34 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
