Knock on startup?
Old Apr 8, 2003 | 06:13 PM
  #16
Silver Z28's Avatar
Same problem here. Mine sometimes does the following,
"start, start, knock, engine doesn't start"
then it goes like this if I try to start it after it has knocked
"start, knock, knock, knock, vrooom, vrooom"
Any more ideas?
Old Apr 8, 2003 | 06:56 PM
  #17
Donny O's Avatar
Originally posted by Lions3
Makes sense, but the engine build pressure while it's cranking. And any shop that does an oil change should be switched on enough to fill the filter up as well.
To me, it sounds like it knocks when it first makes ignition. So it isn't when the flywheel is first engage by the starter, and it isn't once it has hit idle.
It only makes a knocking sound when it's burning up all the accumulated fuel.
Doesn't seem to be hurting anything, or get worse, but it's sorta annoying.
I agree that we are talking about 2 totaly different knocks....mine doew the initial ignition knock as well.
Old Apr 8, 2003 | 11:09 PM
  #18
chasmanz28's Avatar
as i said before it only happens in the winter for some reason, when i start my car, before it turns over, it makes a knock seems like its coming from the driver side area, and i use the best oil out there moble 1 syn and i use lucas stablizer too, and still get that knock when its cold out, thats why i thought it was maybe a dry start problem, but i guessed wrong, any more ideas, in the summer never get the knock if that helps
Old Apr 8, 2003 | 11:27 PM
  #19
LilJayV10's Avatar
what about piston slap? I thought LT1's had that problem for some reason, I could be wrong though, hell wouldn't be the first time
Old Apr 11, 2003 | 01:39 AM
  #20
chasmanz28's Avatar
Old Apr 11, 2003 | 10:55 AM
  #21
Lions3's Avatar
It's not that either. Honestly, it sounds like dieseling for the first split second it ignites. Maybe one or two pops.
Nayr
Mar 3, 2023 08:34 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
