Knock at startup
Old Jul 26, 2006 | 07:54 AM
SApat's Avatar
Knock at startup
Sounds like pre ignition at starting - (cranking)
No audible knock at idle or through rev range - loaded or free revving
I did rebuild opti & installed spline shaft wrong which resulted in knock just off
idle. Re installed opti & checked for knock before replacing waterpump!!
Car runs well except for knock at startup.
Is the opti spline still incorrect or can something else cause this pre ignition ?
Patrick
Old Jul 26, 2006 | 08:35 AM
396D1SS's Avatar
Re: Knock at startup
can you get a sound clip?
Old Jul 26, 2006 | 03:20 PM
SApat's Avatar
Knock does not occur at every start - intermittent
Will try & get sound clip.
Nayr
Mar 3, 2023 08:34 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
